Spec-R R1
Old 11-13-2012, 12:34 PM
  #331
Xenolance's Avatar
Bwa ha ha ha ha! I should get commission or something! I can't wait for Guff to get his S1 so I can drool all over it.
Xenolance is offline
Old 11-13-2012, 08:46 PM
  #332
Trader Rating: 54 (100%+)
I just built an S1 for VTA. When I was putting on the front wheels, they are rubbing on the steering knuckles. Anybody else run into this and if so what solution did you use to fix it.
iadevil is offline
Old 11-13-2012, 08:55 PM
  #333
Xenolance's Avatar
You'd need +.75mm wheel hexes. Something like these:
http://www.nexusracing.com/product_i...roducts_id=291
Old 11-13-2012, 09:00 PM
  #334
Trader Rating: 16 (100%+)
Or just put a .5mm or 1.0mm shim on the axles.
samsking is offline
Old 11-13-2012, 09:03 PM
  #335
Thanks. Would a washer between the wheel and hex work as well? I want to race this weekend and don't think I can get the new hexes in time.
iadevil is offline
Old 11-13-2012, 09:14 PM
  #336
Xenolance's Avatar
Yup! I should have mentioned that as a work around. I tend to not rig things up because then I never go and properly fix them :-P
Old 11-13-2012, 09:18 PM
  #337
Thanks. Can't wait to run the car. Switching from a TC3 to the S1 so should be a great improvement.
iadevil is offline
Old 11-13-2012, 11:56 PM
  #338
Be careful with that. I haven't touched a VTA front in a while, but I vaguely remember them having somewhat shallow hexes. Just make sure the wheel is getting enough engagement on the actual hex to stay put if you tap a board.
-Mike
grippgoat is offline
Old 11-14-2012, 08:10 AM
  #339
Xenolance's Avatar
-Mike
+1
This is why I suggested the wider Hex's initially instead of the washers. Isn't there two different sizes of VTA wheels allowed now, one being slightly larger? Not to mention, most VTA bodies are 200MM instead of 190, so the +.75 or +1.0MM hexes would push the wheels out to make it look better with a 200MM body.
Old 11-14-2012, 09:48 AM
  #340
+1
I haven't put the body on yet to see about clearance but the washers I used pushed the wheels out just far enough that they won't rub but still have some gripping on the hex. Will see how it goes Sunday.
iadevil is offline
Old 11-14-2012, 02:06 PM
  #341
spring71's Avatar
Smile
Spec-R R1/S1 kits and new Hopups have arrived.
FYI, Thanks.
spring71 is offline
Old 11-14-2012, 06:33 PM
  #342
nrtv20's Avatar
What roll bars should I get for this car?
nrtv20 is offline
Old 11-14-2012, 08:15 PM
  #343
Xenolance's Avatar
The R1 has them, the S1 should be good with xray or Tamiya roll bars I think someone said (416/417 I think it was) But they need to be bent just a bit to make them fit.
Old 11-14-2012, 08:42 PM
  #344
+1
With the spacers I used to make the tires stop rubbing, it increased the width by 1/16in or about 1.5mm. The hex itself is about 3/16in or 4.75mm wide. I'm thinking 6mm wide hexes would be about right.
iadevil is offline
Old 11-14-2012, 09:03 PM
  #345
Trader Rating: 19 (100%+)
Hey Eric, This is Brian Bowers. I can let you borrow my Tamiya 6mm hexes this Sunday if you want. I want to see your car! I contimplated on the R1 because of its adjustability and the Red is just sweet. If you want to call me Shiloh and Brian have my number.
429racer is offline
