Spec-R R1
Old 04-21-2014, 12:49 PM
  #2926
rtenzo02's Avatar
Serious, lol, I was trying to find him on youtube just don't know which car he was driving , but after watching the race vids a few times he must be Kayne.
rtenzo02 is offline
Old 04-21-2014, 06:45 PM
  #2927
Kevin K's Avatar
Trader Rating: 32 (100%+)
Originally Posted by rtenzo02 View Post
Hey what color body were you running on your R1 ?
white with some black and red on it...I started 2nd in all races and 1st in the last race as the TQ did not make the start of the 3rd race....yes my last name is Kane
Kevin K is offline
Old 04-21-2014, 09:00 PM
  #2928
rtenzo02's Avatar
Cool Kevin, no one at my local track drives a spec r car other then my spec r s1 that will be hitting the track soon, great to see spec r's perform so well against all the competition out there, keep up the good work !
rtenzo02 is offline
Old 04-24-2014, 01:23 PM
  #2929
rtenzo02's Avatar
Can someone with experience please tell me how much of a difference there is in using hard vs soft lower arms on asphalt ? From researching it seems hard lower arms give better traction on asphalt, is it a noticable difference though in a 17.5 non boost class running on medium grip asphalt ? Is it worth using ARC or tcx hard lower arms vs spec R (non specified) lower arms ?
rtenzo02 is offline
Old 04-24-2014, 01:34 PM
  #2930
R/C Tech Elite Member
JayL's Avatar
If you swap the lower arms for another brand you are going to have to change at least the outer hinge pin as well and maybe then the upright to match the hingepin and then the sway bar mounts may be on a different place on the arm and change the setup more.
My pro-spec, stock, is crazy good on medium grip asphalt so personally I would not change anything
JayL is offline
Old 04-24-2014, 06:31 PM
  #2931
rtenzo02's Avatar
Yea Ive been told to use everything up to the inner pins which would be spec r parts from there, oh well, tqrc is out of stock on the hard lower arms at the monent anyway. Thanks
rtenzo02 is offline
Old 04-25-2014, 05:59 AM
  #2932
32819toon's Avatar
Originally Posted by PEEKracing View Post
32819toon what is that circuit board in the plastic bag?
Yep a transponder. A couple of racers built our system& the transponders cost £20 !
32819toon is offline
Old 04-25-2014, 06:01 AM
  #2933
32819toon's Avatar
Originally Posted by valk View Post
Holy that's an expensive upgrade for an s1 heh. Lookss good though.
Thanks Valk - still half the price of an R1 though !
Old 04-25-2014, 07:02 AM
  #2934
Anyone heard where those S2's are? The boat must be late.
TQ says "late April" but we're running out of April...
.crispy is offline
Old 04-25-2014, 06:27 PM
  #2935
DBM
I finally decided to install my modified 1223 Xray bumper and figured that I should take a photo of how I modified it to fit the spec r. The xray bumper is 18mm thick iirc, and the spec r bumper is 15mm. I milled a 1.5mm pocket on the top and bottom of the bumper to make it fit.
Originally Posted by DBM View Post
I just milled 2mm off of the bumper, but you are right, using a couple of 2mm spacers would work as well.
DBM is offline
Old 04-29-2014, 06:05 AM
  #2936
What am I missing here? Why are we removing material instead of just using longer screws?
.crispy is offline
Old 04-29-2014, 06:59 AM
  #2937
bakoo's Avatar
For the same reason that you use snowshoes and not stilettos when you want to get to your cabin during winter - it distributes the impact force over a larger area.
bakoo is offline
Old 04-29-2014, 07:17 AM
  #2938
Ummm... don't know what that had to do with anything...?
The Xray bumper, while harder, is also thicker. However the all important holes line up I assume? But, if you just slide it on and attempt to slide the mounting plate down, the existing screws aren't long enough to reach the threads on the bottom.
Thus, why I assume DBM removed material from the top and bottom. My question, why not just get longer screws?
.crispy is offline
Old 04-29-2014, 07:22 AM
  #2939
valk's Avatar
Its easiest to just shim it. Not all of us can mill things when we want heh. Very clean though.
Mine arrived the same way.
valk is offline
Old 04-29-2014, 07:30 AM
  #2940
Arrrgh!
What you mean "shim"? Shim implies adding spacers like washers to add thickness. I thought the Xray bumper was already too thick?
How does one shim something to make it thinner/smaller?
I'm not understanding...
.crispy is offline
