Spec-R R1
Old 03-27-2014, 11:58 PM
  #2776
OldfartWal's Avatar
Originally Posted by PEEKracing
I use the Velcro strap, but I don't like it, don't like tape for that matter either. I dislike the strap because it flexes the chassis, so my ground clearance under the battery is lower than under the bulkheads, and means my chassis is tweaked any time there's a battery in it. I'd like to devise a little clamp style holder someday that holds the battery but doesn't directly exert any force on it, keeping everything as free as possible.
I use the factory strap & velcro tape to hold the battery in, it has still come out (once), but if you use velcro tape you don't need to pull that hard on the strap.
Hey Marty, I'll be there tomorrow (weather permitting), I'll have the lowering kit but not the engine mount, I'm not racing, I'm playing chef again & I need to get some more info from the bike guys (mine is nearly ready to run).
I've got the ball diff in the rear of the ProSpec, I may do one qualifying heat, then put it away, I have to work a 12 hour shift on Sunday so won't be staying for the finals, hope we can get the R1 running faster than the old S1, by the end of the night.
Oh & change your freakin' signature , you now have a R1 & the S1. LOL
OldfartWal is offline
Old 03-28-2014, 12:14 AM
  #2777
spring71's Avatar
Smile
New Spec-R S2 kits Pre-Order is available at TQ.
http://www.tqrcracing.com/shop/product_view.asp?p_id=7718
FYI, Thanks.
spring71 is offline
Old 03-28-2014, 05:22 AM
  #2778
Jorge T's Avatar
Trader Rating: 14 (100%+)
Well I'll check out his video. I'm sure they're built right. How much air? I don't know how to measure that, but when I compress the shocks, at least one of the four will make a squishy sound.
Like this one? RSD product
Jorge T is offline
Old 03-28-2014, 06:48 AM
  #2779
PEEKracing's Avatar
Indeed, is that the one marketed for Xray?
PEEKracing is offline
Old 03-28-2014, 07:09 AM
  #2780
Jorge T's Avatar
Yes it is the one for the XRay adapted to the R1.
Jorge T is offline
Old 03-28-2014, 04:03 PM
  #2781
Butler02's Avatar
That's a pretty sweet idea for battery retention. I might try to make something like that out of a peice of broken chassis and those chassis stiffening posts that come with the kits.
What I've seen a few other guys do to prevent tweaking the chassis is they use a small strip of servo tape at either end of the battery to help keep it from moving around and allows the strap to be a little less tight so as not to bend the lower chassis plate.
Butler02 is offline
Old 03-28-2014, 05:03 PM
  #2782
valk's Avatar
I might try motherboard risers. I baught like 50 to rebuild my desktop. They handy and scree into each other. Thus adjustable length.
valk is offline
Old 03-28-2014, 05:18 PM
  #2783
SteveM's Avatar
Trader Rating: 165 (100%+)
Tuning Haus make Tape Eliminator kits for various cars and you might adapt one for the R1. I use one on my Mi5 and it works perfectly. TQ Racing sells them.
SteveM is offline
Old 03-28-2014, 07:47 PM
  #2784
valk's Avatar
top plate broke.. sooo low cost lower tech
valk is offline
Old 03-29-2014, 06:15 AM
  #2785
mrjudd77's Avatar
OK so went racing today for an all scales/ open day. The weather was stupidly humid after a week of solid rain. The track was slippery, like it was covered in ice on some sections. Made the new car very hard to dial in. By the end of the night (I cut it short and didn't run in the finals) I was having massive problems with it going random directions. I had one of the better drivers have a look at it (thanks to CountryHick) We have put it down to faulty electrics, either the servo or radio. Plus the shocks need rebuilding again as I lost 2mm ride height in the front and gained 3mm in the rear.
mrjudd77 is offline
Old 03-29-2014, 08:18 AM
  #2786
PEEKracing's Avatar
When my outter hinge pin broke, the car seemed to be going randomly where it wanted, also did similar things when the sensor wire wasn't plugged in right. It seems that it's not enough to plug in the connectors, you also need to seat each contact individually with a small blunt to, they seem to have an extra half mm or so that they need to be fully reliable.
Old 03-30-2014, 01:30 PM
  #2787
RE: Spec-R S1
So, thanks for answering my question about the shocks; now I know what to look for.
What about a motor mount with some more adjustment to it?
JimmyMack12 is offline
Old 03-30-2014, 02:58 PM
  #2788
Butler02's Avatar
Why do you need a larger adjustment? You should be able to get all the adjustment you need with what's already available. Pick a spur gear size that will give you the range of ratios you need with the pinions you have.
I've seen other people use a dremel and small bit to slightly enlarge the slots for a little bit more play.
Butler02 is offline
Old 03-30-2014, 03:12 PM
  #2789
Because I don't want to have to keep changing spur gears in and out to get the gearing I want/need. I've run all kinds of spurs from a 84-tooth (64-pitch) to a 108-tooth (which won't let me put in any bigger pinion than about a 30-tooth). Changing that spur gear in and out is a pain in the a$$. Hell, even changing the pinion isn't all that easy on these touring cars (when you're used to running pan cars...LOL)
Old 03-30-2014, 03:28 PM
  #2790
Butler02's Avatar
What gear ranges are you looking for?
Butler02 is offline
