Spec-R R1
Old 03-27-2014, 05:09 AM
  #2761
PEEKracing's Avatar
Do any of you find you need to top of the shock oil after just about every race day? I usually have at least one sick that got some air in it.
PEEKracing is offline
Old 03-27-2014, 09:58 AM
  #2762
DBM
Now that I've owned the car for a few weeks, I've had it out to three practice nights, and one race day. I must say that I am RIDICULOUSLY IMPRESSED with the durability of this kit. My driving is pretty bad, and I crash A LOT (I'm a noob). The only issues I've had were: tamiya ball cup popped off of the right front c-hub, and the battery came loose from one end of the holder since I didn't strap it down tight enough with the velcro strap. The rest of the guys in my club seem to be decently impressed with the car, considering its price.
To any noobs considering getting a spec-r, do it!
DBM is offline
Old 03-27-2014, 10:11 AM
  #2763
valk's Avatar
Wow. Lol popping a tamiya cup must take some force.
Now that i think.of my failures, maybe I've just had the steering blocks tightened too much.
Maybe ill back the screws off and put a little locktite on there.
As for air in shocks... how much air? Never had tc shocks that were totally leakfree.
I usually refill mine every couple race days. Oil has been clean everytime so oring doing its thing.
Make sure the bottom cartridge is facing the right way.
valk is offline
Old 03-27-2014, 10:16 AM
  #2764
k_bojar's Avatar
Trader Rating: 30 (100%+)
Originally Posted by valk
I follow chris graingers shock build procedure and get a perfect shock every time, even with the $20 spec r's.
I'd be curious to see this procedure ... any link to it?
k_bojar is offline
Old 03-27-2014, 11:16 AM
  #2765
Default Re: Velcro strap
I like them. The other guys (AE, Xray) look at my velcro straps with disdain and replace their tape every other run it seems like. Then at least once a race night, one of those guys loses a battery on the track.
Why such an aversion to the strap? They don't weigh that much. In the classes I run (VTA, USGT) I'm adding weight anyway.
.crispy is offline
Old 03-27-2014, 11:19 AM
  #2766
k_bojar's Avatar
I think its the perceived lack of security with with the straps.. i'd rather use tape because I know it'll stick to the battery, as opposed to just holding it
I know I probably won't use the strap and go with tape, but its just a perference
k_bojar is offline
  #2767
valk's Avatar
http://m.youtube.com/watch?v=srg9Glepzmk
To add to this procedure, ill loosten/tighten the caps to get rebound equal for a pair of shocks.
Once the cap is on and tight, very small adjustmebts to it are all that's needed.
valk is offline
Old 03-27-2014, 11:22 AM
  #2768
DBM
I googled "chris grainger shocks rc" and a youtube video of Chris Grainger rebuilding shocks was one of the first results
Edit: I'm too late....oops!
DBM is offline
Old 03-27-2014, 01:15 PM
  #2769
PEEKracing's Avatar
Well I'll check out his video. I'm sure they're built right. How much air? I don't know how to measure that, but when I compress the shocks, at least one of the four will make a squishy sound.
I use the Velcro strap, but I don't like it, don't like tape for that matter either. I dislike the strap because it flexes the chassis, so my ground clearance under the battery is lower than under the bulkheads, and means my chassis is tweaked any time there's a battery in it. I'd like to devise a little clamp style holder someday that holds the battery but doesn't directly exert any force on it, keeping everything as free as possible.
Old 03-27-2014, 01:24 PM
  #2770
valk's Avatar
Watch video. Do what he does and no air. In short. Fill abd bleed the shock fully. I find it quickest to have the rod all the way up, fill up to he brim, slowly drop the rod to dispose. Bubble. Repeat til shock at bottom.
Wait for air to bleed.
With oil right to the top; and your chosen reboud set, drop in the diaphram, float it around with a driver bit, seat the cap on the threads and push the plastic cap down as you do up the cap.
Once you have two, screw around with tightness of caps to get equal rebound.
I could do a video if it helps but I really just copy him lol.
valk is offline
Old 03-27-2014, 08:19 PM
  #2771
rtenzo02's Avatar
Bout the only thing I noticed so far on the S2 that appeals to me is the top deck, looks like it would allow more flex than the S1 top deck. Like to see that design in a R2 carbon version. Jmo !
rtenzo02 is offline
Old 03-27-2014, 09:01 PM
  #2772
Butler02's Avatar
The lower chassis plate looks like the option chassis that came out for the r1. I have it and the standard r1 top deck on my 17.5 blinky touring car. It works awesome. The design should carry over to the s1 materials well.
Butler02 is offline
Old 03-27-2014, 09:18 PM
  #2773
valk's Avatar
I never understand those narrow chassis plates though. what would you rather have hit the ground? a cheaply replaceable peice of carbon fiber or your $90 motor, or $90 battery? lol.
nice to see them making updates to the car. however small.
will this mean a new r1 kit or an option upgrade to prospec kits?
valk is offline
Old 03-27-2014, 10:03 PM
  #2774
Butler02's Avatar
wide chassis or narrow, you shouldn't have anything dragging on the ground. That's bad juju.
Butler02 is offline
Old 03-27-2014, 11:44 PM
  #2775
mrjudd77's Avatar
bring on the new SpecR R2. Can't wait to see the upgrade parts for the R1. I haven't even run my R1 yet but love the fact there are new bits on the way
mrjudd77 is offline
