Spec-R R1
#2326
#2327
my setup on low grip carpet was box stock with following changes:
rear shocks in hole 4 on tower, 35wt oil in all 4, tamiya white springs in front, blue in the rear
camber links in inner position on bulkheads (long links) 3mm spacer under inner position front and rear
#2328
Appreciate that.
Thanks, appreciate the feedback and extra info.
#2329
I do not have the spec-R brand of DCJ's so I cannot compare. The CVD's that came in the box seem to have less play in comparison.
#2330
#2331
As much as I love my R1s, I think front/side impacts have a pretty high chance of breaking something. I broke the front C-hubs and steering blocks on several occasions, along with the lower pins. This is in 25.5 by the way. But, parts are cheap enough and fast enough to replace, so I stick with it.
#2332
I wonder if the breaking is temp related or a batch.
my track has boards
I have hit chicanes on a front wheel full throttle and had the car jump straight up 3-4 feet with no break
I have been nailed at a stop at the end of the straight other car full throttle no breaks
all multiple times no issues
S1
my track has boards
S1
#2333
my track has boards
S1
my track has boards
S1
#2334
The meeting before last, I was 'dated' hard enough to launch the car about 5 to 10 metres through the air, then hit (again from behind) in the final hard enough to completely dislodge a rear shock (outdoors so never found it either).
Broke a rear pivot pin (must have been fractured) & put the car fairly hard into a unforgiving concrete barrier whilst at practice, tearing the whole front left suspension off.
Total cost to repair was about AUS$15, time to fix was about 10 minutes, not sure how a different brand would have fared, but my R1 was simple & cheap to fix.
Yep, stuff breaks, but have a quick comparison between the SpecR spare prices & the other 'name' brands & you can see why you are starting to see more SpecR cars around.
Not made better or worse than the other brands, but cheaper to fix when it does go a bit pear shaped.
#2335
Back when I had been racing for a year or two, I'd break stuff on my Shumacher Mi4 LP all the damn time. At least once per race night. C-Hubs, steering knuckles, hinge pins, hinge pin blocks, rear hubs, arms, whatever. I crashed a lot.
Same car, same class, 3 years later, I still crash sometimes, but I haven't broken anything for over a year. I still crash sometimes, sometimes still spectacular. But nothing breaks. Even in Modified this summer with the Mi4 CXL (same suspension design and plastics), I crashed a lot, some of them pretty spectacular, and never broke anything but a DCJ.
I think there's just something about how we crash when we're learning that breaks cars. Seemingly harmless low-speed smacks into a pipe can sometimes pack more of a punch than a spectacular-looking but glancing launch off a high-speed kink.
-Mike
-Mike
#2336
I think you are right Wal and Gripgoat. We tend to crash differently when new. I have only been racing for 12 months and for the first few months I was constantly breaking stuff and loosing bits during crashes (on my HPI Sprint 2). Since I have started racing with the SpecR I have noticed less breakages and lost parts. The car holds together better. I had originally put it down to the car itself, but I have improved my driving and changed receivers as well which also contributes to the durability of the car. Can't wait to see how it stands up to a full season of abuse both outdoor and indoor.
#2337
lol, so I am 'good' at crashing?
Does that count as a skill or just years of crashing made me good at it?
#2338
Waiting to see you at the track MRJ, RDS turned up last meeting, so we had 2 SpecR's in the field, my Pro Spec is built, just waiting for speedie & motor, heading down to the track today to price up a 2nd (& 3rd) transponder.
Not running the Pro Spec indoors, I'll be getting a 12th pancar & maybe using the R1, outdoors I'll drive the Pro Spec & having 'guest' drivers (as I have already said), drive the R1.
Kermit green may be going, I'll see, but looking to put some very ugly fluro colour schemes together.
#2339
