Spec-R R1
Old 07-08-2013, 10:06 AM
  #1621
R/C Tech Elite Member
EricW's Avatar
Originally Posted by VenturaDC
Building my order and have a few question
Does the s1 come with universal or dog bones?
Does the kit come with what i need to mount sway bars?
I tried to download the manual but my new fancy android phone won't open pdfs for whatever reason
S1 does not come with swaybars
EricW is offline
Old 07-08-2013, 10:30 AM
  #1622
VenturaDC's Avatar
Trader Rating: 32 (100%+)
I understand that, there already in my shopping cart. I was just wondering about the little bits to mount them. I saw the rod pass thru holder things in the parts category so i didn't know if it came with them or had to piece them together.
VenturaDC is offline
Old 07-08-2013, 11:24 AM
  #1623
SteveM's Avatar
Trader Rating: 165 (100%+)
The S1 kit includes some, but not all of the hardware needed to add sway bars. You need sway bars of course, but you also need the following;
- extra ball cups #SPR-R1P306
- ball studs #SPR-R1A101
- rod stopper #SPR-R1A123
- M3x3mm grub screws
- misc M3x10mm bevel head bolts
SteveM is offline
Old 07-08-2013, 11:54 AM
  #1624
VenturaDC's Avatar
Thank you!
Old 07-09-2013, 06:25 AM
  #1625
EricW's Avatar
Are some parts on the R1 and an Xray car interchangeable? Would it be worth swapping out parts on the R1 for the Xray ones?
EricW is offline
Old 07-11-2013, 05:05 PM
  #1626
SamuraiJack's Avatar
Trader Rating: 41 (100%+)
On my S1 the long belt gets a bit jumpy at full throttle but it seems fine. However when wheels are turned fully in either direction the slightly jumpy belt rubs against steering linkage. I'd rather not tighten up the belt, is that my only option?
My S1:
SamuraiJack is offline
Old 07-11-2013, 07:48 PM
  #1627
big al's Avatar
A belt should never rub at all, ever.
big al is offline
Old 07-11-2013, 11:41 PM
  #1628
metalnut's Avatar
Trader Rating: 36 (100%+)
+100
Can you take a picture of what's rubbing? I'm guessing something isn't assembled correctly.
metalnut is offline
Old 07-12-2013, 06:42 AM
  #1629
I found this pic that shows what I am talking about:
See how when fulling turned the steering arms overlap the belt? At full throttle my belt jumps enough to graze the bottom of the arms at full turn. Maybe its just too much jump in the belt?
Another pic, you can see how close the bottom of the arms are to the belt:
Thanks!
Originally Posted by metalnut
+100
Old 07-12-2013, 10:14 AM
  #1630
bakoo's Avatar
Maybe you have too many degrees of steering - do (one or both of) your wheels stop turning before you've turned the steering wheel completely over? If so, adjust the endpoints on your radio (reduce the EPA percentage) so the servo stops turning before the wheels actually rub against something.
bakoo is offline
Old 07-12-2013, 11:54 AM
  #1631
Cody_ferone's Avatar
Trader Rating: 16 (94%+)
Default Dealers
I no rcmart stocks the s1 but I would prefer to go through a u.s based company. Reflexracing sells them but there out of stock. Any one no of another dealer in the states that has the s1 in stock?
Cody_ferone is offline
Old 07-12-2013, 12:00 PM
  #1632
I guess I don't know what is too much.
Old 07-12-2013, 12:07 PM
  #1633
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
http://www.tqrcracing.com/shop/produ....asp?p_id=4744
IIGQ4U is offline
Old 07-12-2013, 12:19 PM
  #1634
Just put one on order super excited to get it. I read Somewere you could use xray belts?
Old 07-12-2013, 02:17 PM
  #1635
bakoo's Avatar
If you slowly turn the steering wheel until the wheels can't turn any more, and notice that the steering wheel (and more important, servo arm) can still move even more, you need to tell your transmitter to restrict the servo arm from traveling beyond that point (endpoint).
Squirrel made a video that shows how this works: http://www.youtube.com/watch?v=EqJ5ws7sv04
bakoo is offline
