KO Propo EX-1 Mars..."Back Up Error"????? >
Old 07-19-2002, 11:07 PM
Impreza's Avatar
Default KO Propo EX-1 Mars..."Back Up Error"?????
Today my KO Propo Mars suddenly gave a few weird beeps, lost control of my vehicle, and now has "Back Up Error" stuck on the LCD screen. None of the buttons work to adjust anything, only the 2 quick trims on the wheel, but I still have control of my vehicle.
What does that mean? I have searched in the manual and cannot find anything about this. Has the backup battery inside finally packed it in? If so, do I HAVE to send it back to KO for them to replace it?
Any comments or thoughts would be greatly appreciated.
Thank you very much.
Impreza is offline
Old 07-19-2002, 11:32 PM
The only thing I see about "Error" in the manual is "memory error" and they say you have to send the transmitter in to the service repair department.
They also say "Although it seems to function normally, sudden misoperation may occur".
ZER01 is offline
Old 07-20-2002, 12:10 AM
Registered User
Default Re: KO Propo EX-1 Mars..."Back Up Error"?????
Email them.
[email protected] <[email protected]>
thatdog is offline
Old 07-22-2002, 03:58 PM
Kevin K's Avatar
Trader Rating: 32 (100%+)
What the back up error means is that the watch style battery that is soldered to the board in the radio is below is operating voltage. The battery is used to keep all your trim memory or else you would loose it all when you took the battery out or it would drain your battery pack when its not on. You need to send the radio in to KO so they can replace the battery or if you are very very carefull you can do it but take a look and see how its in there first and you will see its something they should do. I had this happen on two of my radios my old EX10 and EX 1precious
Kevin K is offline
Old 01-09-2008, 12:41 AM
mangoman's Avatar
Old thread, but i have a Mars EX-1 R that his has happened to.
I just pulled the entire thing apart, and believe me you dont want to do it cause its a real pain desoldering the boards on this model AND there is no battery inside.
mangoman is offline
Old 12-01-2012, 07:56 PM
policeman0077's Avatar
I didn't find the battery either. So did you finally solve the problem?
policeman0077 is offline
