Old 03-13-2005, 11:29 PM   #16
burbs's Avatar
Send a message via AIM to burbs Send a message via Yahoo to burbs
hurricane packs are very good.. and i was at the shop today they had 1.17+ at 30 amp for 42.99 a pack... 60 dollars for the packs you listed before is quite high in price..
burbs is offline   Reply With Quote
Old 03-14-2005, 01:58 AM   #17
Regional Moderator
daniz24's Avatar
I've seen Hara's GP3700 battery for sale after the TITC and has 1.120 with unbelieveable price... Hmmm, not interested
daniz24 is offline   Reply With Quote
Old 03-14-2005, 09:06 AM   #18
dgullickson's Avatar
Trader Rating: 45 (96%+)
Send a message via AIM to dgullickson Send a message via Yahoo to dgullickson
Buy Packs Matched @ 30AMPS, it is more true to what we are drawing amperage wise with our motors. You get a more true feel of what you are getting. We do all ours at 30AMPS and get 400+ w/ 1.170+ with an IR of around 17 all @ 30 AMPS.
dgullickson is offline   Reply With Quote
Old 03-14-2005, 10:01 AM   #19
primusblowsgoat's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to primusblowsgoat Send a message via Yahoo to primusblowsgoat
wallstreet, what shop did you see them batts at?
im in carol stream, didnt know any shops around here had a so called "buyers club"
i know liesure hours will give you a lil discount if your in there all the time and race at their track
Schumacher Racing
Schumacher Cat SX2
Schumacher Cougar SV
primusblowsgoat is offline   Reply With Quote
Old 03-14-2005, 11:59 AM   #20
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
it was hobby town in naperville. they have this club card thing. i think a new owner has taken it over but they dont seem to carry much rc stuff.
wallstreet is offline   Reply With Quote
Old 03-14-2005, 12:08 PM   #21
i cant stand that store, been in it maybe twice, just cause i was driving by it, ill never give them my money
Schumacher Racing
Schumacher Cat SX2
Old 03-14-2005, 12:34 PM   #22
raving-monkey's Avatar
Send a message via MSN to raving-monkey
and considering you can get team orion 1.19+ 400+ at 30amp...these cells at 20amp don't seem all that good to be honest.
raving-monkey is offline   Reply With Quote
Old 03-14-2005, 12:42 PM   #23
berger's Avatar
R/C Tech Charter Subscriber
Pro match are/were selling their best 1.185 packs which are a real 1.185 on their site. Steve has their 1.175+ 390s+ ones at $49.99 on his site
berger is offline   Reply With Quote
Old 03-14-2005, 03:26 PM   #24
robk's Avatar
Trader Rating: 22 (100%+)
When Brad returns from the carpet nationals, give him a call at Hurricane. They advertise here. Brad finsihed matching up cells just recently, so I'm sure they have plenty of good stuff in stock.
Old 03-14-2005, 03:41 PM   #25
You should consider fusion batteries. There having a sale right now and you can get some great deals. I just started using there packs a few weeks ago an can honestly say they are the best packs i have used in the 19 years i've been in the sport. Plus John or someone is always on here who can help you out with questions. You can see there sales at
www.fusionbatteries.com
good luck
scott howard
SCOTT HOWARD is offline   Reply With Quote
Old 03-14-2005, 05:25 PM   #26
ChadCapece's Avatar
When I hear guys comparing Orion packs to any other company, it makes me sick. Orion is doing just what integy and other companys that have "sneaky" ways of hiding lesser packs in with better packs. Orion matches cells using Lavco matchers. They are completely different from the TurboMatchers that most honest companies use. Lavco gives 1.19 numbers in comparison to 1.17 cells. And to a newer racer, they will buy the pack with the highest numbers not knowing that they are being fooled. I would like to see every company charge at 6 amps. Discharge at 30, .90 cutoff, 5000DET all on a TurboMatcher.
Watch out for companies using any of the following:
Non TurboMatcher matchers
.85 cutoff
20 amp charge
300 DET
cool temp discharging rooms
If you see a pack with higher than normal runtime, voltage, or IR. As youself what is different about their matching process.
ChadCapece is offline   Reply With Quote
Old 03-14-2005, 05:50 PM   #27
Mal
Registered User
Actually, Orion uses turbomatchers. The variable discharge method they use is what makes the voltage numbers so high.
Mal is offline   Reply With Quote
Old 03-14-2005, 07:12 PM   #28
imjonah's Avatar
Default This ain't that complex
Make/buy little light bulb discharger (normally they are 20 amps
you can add 5 more bulbs and make them 30 amps)
Get a piece of graph paper a stop watch and a cheap little $20 digital voltmeter.
1. Charge the Battery
2. Connect the battey to the discharger
3. Every 30 secs record the voltage
What you will see is a graph with a long flat spot gently sloping downwards from about 30 secs out to around 6+ minutes.
Repeat the above with a alternative charging method or battery. COmpare results
imjonah is offline   Reply With Quote
Old 03-15-2005, 10:39 AM   #29
Default actually, it's slightly more complicated
Light bulbs do not draw constant amperage. Sorry.
TPJ International
071crazy is offline   Reply With Quote
Old 03-15-2005, 07:55 PM   #30
imjonah's Avatar
Default "Light bulbs do not draw constant amperage"
neither does the car,
I was trying to describe a test you can do without expensive equipment.
Is there something else which is cheap and would give you a known amp drain?
1/12 ALL EYES ON YOU AIRBRUSHED BODY superslow R/C Items: For Sale/Trade 4 04-01-2007 12:53 PM
proline snake eyes 2 pair jimstoyz R/C Items: For Sale/Trade 0 11-03-2005 03:55 PM
proline snake eyes tires t4driver88 Wisconsin & Illinois Racing 1 08-09-2004 11:46 PM
smoke in the eyes nitrosaurus Nitro On-Road 10 06-17-2003 07:26 AM
