Like Tree54Likes
Old 04-03-2014, 09:04 PM   #1411
DesertRat's Avatar
Does anyone still run an upright servo in this car or am I the only one?
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. Losi 22 4.0, CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 04-03-2014, 09:07 PM   #1412
ghoppa's Avatar
Trader Rating: 54 (98%+)
Originally Posted by Andrew S View Post
I think it would help. Why can't you just add shims to the axle?
166 is pretty narrow.
I don't know the exact term but that's a change I am not looking for vs just track width by widening the geometry of the arms and not by shimming out the wheels from the axle
R1 Wurks - ActivRC - ApexRC - P1 Brands
ghoppa is offline   Reply With Quote
Old 04-03-2014, 09:20 PM   #1413
are you wanting longer arms to reduce camber gain? as well as width?
Andrew S is offline   Reply With Quote
Old 04-04-2014, 07:00 AM   #1414
Widening the track width via front axle shims will also affect scrub radius... whereas altering the width via the lower control arm(ie: adding shims b/w the bulkhead and arm a la AE) will not.
This is one of the reasons the Xenon front end is cool... you can adjust the kingpin inclination angle independently of camber, thus changing the scrub radius.
JamesL_71 is offline   Reply With Quote
Old 04-04-2014, 02:36 PM   #1415
DesertRat's Avatar
I'm going to be racing this car in full-length limo mode at the mile high champs. Long chassis and long rear pod plate from an altered ego. The spot where I have to cut the rear holes in the body is comical, but the long wheelbase should calm the car down!
Now all I need is some talent...
Old 04-04-2014, 03:18 PM   #1416
I wonder how the wheelbase in the long mode compares to the new Kyosho...would love to be able to run that Kyosho 962 body
Old 04-19-2014, 01:44 AM   #1417
I)arkness's Avatar
i need more steering mid corner on throttle, would one i go a harder center shock spring or side springs
B.Portelli
Hyper RC - RAB Hobbies - Wild Turbo Fans
Race Opt - Team Powers
I)arkness is offline   Reply With Quote
Old 04-19-2014, 01:48 AM   #1418
garrysingh817's Avatar
woww car looks amazing
garrysingh817 is offline   Reply With Quote
Old 04-19-2014, 06:54 AM   #1419
WIITA's Avatar
Trader Rating: 42 (100%+)
What sides are you currently using? Better yet, what's your setup. What surface?
Team CRC / Sanwa / Team scream / Genesis RC / Hobbywing / TQ Wire / Schelle / MIP / RC^2 / TEKNO / BoomRC
WIITA is offline   Reply With Quote
Old 04-20-2014, 12:42 AM   #1420
I)arkness's Avatar
here is what i was running
B.Portelli
Old 04-20-2014, 07:57 AM   #1421
I think you would get more on-power steering with the trailing front axles as you use the maximum amount of castor on your setup sheet. Have you tried that?
davidl is offline   Reply With Quote
Old 04-20-2014, 02:49 PM   #1422
The sheet doesn't show how much front droop you have if any. If you do have front droop try reducing it. Also when I go carpet racing in Vegas I notice the mod guys often run softer fronts than rears. I don't run mod though so I can't say why they do it...only an observation that I've made.
Old 04-21-2014, 09:22 AM   #1423
Are you actually running inline axles? Or is that a misprint?
Old 04-21-2014, 12:04 PM   #1424
tim fry's Avatar
Has anyone got any tips for identifying the new non painted side springs?
tim fry is offline   Reply With Quote
Old 04-21-2014, 12:19 PM   #1425
al dente's Avatar
Measure the wire diameter.
Team CRC / Dumper's Speed Shop / Team Scream Racing / Black Art
RC America / FB/FX / Colorado On Road RC Club
5280 Raceway (5280raceway.com) home of the MILE HIGH INDOOR CHAMPS April 19-22, 2018
al dente is offline   Reply With Quote
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 567 11-20-2017 04:06 PM
