Like Tree54Likes
Old 08-05-2013, 05:29 PM   #1156
Originally Posted by InspGadgt View Post
The stock chassis is in-line only. The Altered Ego kit allows you to run the car with the battery crosswise. I run mine in-line in 13.5 blinky and like it a lot. But it comes down to personal preference.
hey thanks a lot as always
cyrrus is offline   Reply With Quote
Old 08-06-2013, 06:24 PM   #1157
Trader Rating: 20 (100%+)
Anyone looking to sell an xti?
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 08-06-2013, 10:23 PM   #1158
Johnny Wishbone's Avatar
Yes, shoot me a pm with your offer..........just a roller.
Gary Lanzer
Old 08-10-2013, 12:31 AM   #1159
I)arkness's Avatar
here is mine almost ready to go, just waiting on some parts to arrive, and some nice weather to paint the body.
Team CRC Xti 1/12th Scale!!-crc-xti.jpg
B.Portelli
Hyper RC - RAB Hobbies - Wild Turbo Fans
Race Opt - Team Powers
I)arkness is offline   Reply With Quote
Old 08-11-2013, 04:53 PM   #1160
Wade....'s Avatar
Default Got a old GenX on the shelf... help me out!
http://www.rctech.net/forum/r-c-item...l#post12436721
Sorry to interrupt the thread.
Wade Huesman, TCORC Secretary/Pencil Pusher
Wade.... is offline   Reply With Quote
Old 08-26-2013, 02:49 PM   #1161
seth556's Avatar
Trader Rating: 42 (100%+)
Selling my XTi, need to pay some tuition.
WTS CRC XTi
seth556 is offline   Reply With Quote
Old 08-28-2013, 09:15 AM   #1162
danthrc's Avatar
Originally Posted by I)arkness View Post
did anyone else running the spektrum h5020g servo have issues with mounting? as the only way i could get it o fit was to dremel the carbon brace the arms mount onto.
im hoping it hasn't weakened it to much that it will not crack in an accident?
I had the same issue and dremeled as much as I could to get it to fit and just couldn't get it where I felt good about it. I went ahead and picked up the JR servo and it worked great.
danthrc is offline   Reply With Quote
Old 08-28-2013, 05:54 PM   #1163
I)arkness's Avatar
i got it to fit in ok in the end, however making ride height chances take a little longer, but mainly annoyed with the servo saver wasn't what you call centered at all, so i think im on about 40 to 60 left on sub trim.
but overall worked quite well and seemed to run straight without any issues.
B.Portelli
Old 09-04-2013, 10:34 AM   #1164
martymiller's Avatar
Does anyone know the countersink angle for the 4-40 flat head screws?
martymiller is offline   Reply With Quote
Old 09-04-2013, 11:06 AM   #1165
Need to get ready for the IIC...I'm still running the stock chassis layout. Anyone got a good setup and tires for the IIC?
Old 09-04-2013, 02:17 PM   #1166
Trader Rating: 60 (100%+)
Standard is 82 included
MC112b is offline   Reply With Quote
Old 09-04-2013, 07:30 PM   #1167
Here is Wayne's setup from Cleveland - 17.5 Blinky
Originally Posted by sg1 View Post
Hey Guys,
I just got back from the US Indoor Champs and thought I'd share my set up info with you.
I ran 1/12 17.5 Masters, TQ'ed and won the main with the following set up:
.50 front springs (.01" gap between steering block and lower pivot)
10* blocks
1* camber
black fronts at 1.62"
3.5mm clearance
stock shock oil
red spring
1.5mm droop
outside of tubes raised with 20k
orange side springs
3.5mm clearance on back of chassis
3.5mm clearance on front and back of lower pod plate
magenta rears at 1.66"
Team CRC is offline   Reply With Quote
Old 09-04-2013, 10:58 PM   #1168
Oops...i should have said for 13.5 blinky
Old 09-05-2013, 07:13 AM   #1169
For 13.5, I would go to blue side springs, Magenta front tires, Pink rear tires, 20k in tubes (you could start with 10k, but be prepared to go up as the grip builds) and a Black Art Black Market (aka Mohawk) body. I would also be ready to go to .55 front springs.
dumper
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 09-05-2013, 01:40 PM   #1170
Cool thanks Dumper! That's pretty close to the setup I run now on asphalt. .55 front springs, blue side springs, white center spring, 10k oil on the tubes. Except on asphalt I'm runing 2x pink fronts and pink rears.
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 567 11-20-2017 04:06 PM
