Like Tree54Likes
Old 03-01-2013, 03:41 PM   #991
Originally Posted by Radi0Flyer View Post
Under what circumstance would that break? Rear impact? I got a solid shunt on my last time out that chewed my spur but the pod plates look fine.
Sean
took a shot on the l/r when i went into a right hand sweeper and tore the screw out of the center....not sure how the 2nd one got broke ...i hadn't hit anything..the handling became very erratic and when i pulled it in the give it a once over i found another plate was broken...only thing i can think of is either i had a screw back out slightly or the plate was defective in some way.
The Hobby Shop,The Ohio RC Factory
T.O.P. Photon CRC XTI, XRAY T4 15 xray xb4 xb8e losi sct 2.0
insanity takes it's toll...please have exact change
bpalmer is offline   Reply With Quote
Old 03-01-2013, 03:56 PM   #992
theatriks's Avatar
I had the plate break on me too ...where the rear link screw goes through....im not sure how it happened either....its in such an odd spot im not sure how it happened....i called crc to see if it was covered but there only covering the front of the chassis if that breaks you can send it in for a new one.
theatriks is offline   Reply With Quote
Old 03-01-2013, 04:44 PM   #993
Csaari77's Avatar
Trader Rating: 34 (100%+)
I've broken 2 pods plates. Both broke in the same spot. The left side link ripped out.
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 03-01-2013, 05:43 PM   #994
theatriks's Avatar
Thats exactly what happened to mine.
Old 03-01-2013, 06:52 PM   #995
Mine broke on the center pivot hole but mine was a really hard hit...probably would have broken any other car out there too
Old 03-01-2013, 07:11 PM   #996
Csaari77's Avatar
Both of mine were fairly light hits. The first plate lasted through some pretty hard shots though. The second plate lasted about 6 easy runs.
Old 03-01-2013, 07:59 PM   #997
Radi0Flyer's Avatar
I was checking screws after every run and I had a couple on the bottom of the pod coming loose. I figured it was normal break-in and just kept tightening them. Maybe I will use threadlock on them.
Thanks for the info.
Sean
I'll drive it til the wheels fall off and burn
Radi0Flyer is offline   Reply With Quote
Old 03-02-2013, 09:31 AM   #998
tdu verney's Avatar
What all comes in the Altered Ego, item #3226?
tdu verney is offline   Reply With Quote
Old 03-02-2013, 11:19 AM   #999
Trader Rating: 24 (100%+)
Send a message via AIM to Max K
How are you guys breaking the rear pod? I have hit some stuff pretty hard in my mod car and I have yet to break any carbon parts.
Chassis #3223 Altered Ego Rear Bottom Plate - #3224 Altered Ego Rear Top Plate - #3225
RC America - XRAY - HUDY - Trinity - ORCA - Sanwa - ULTI - PROTOform - MaxFX - Slapmaster Tools - ApexRC - SXT
Max K is offline   Reply With Quote
Old 03-02-2013, 07:21 PM   #1000
Csaari77's Avatar
I've now broken 3 pods. Had one break today in a main. I had another car bounce off a wall into the side of my car and it broke on the impact side. It seems like they are breaking if the impact is a specific angle because the link attachment point is exposed outside of the main chassis plate. It's becoming incredibly frustrating to say the least.
Old 03-03-2013, 01:53 AM   #1001
BCbud's Avatar
Trader Rating: 37 (100%+)
With the side links closer to the center, an impact on the wheel or rear pod will have more leverage or mechanical advantage on the side link ball mounts. This is why the pod is breaking more often than with the wider mounted side links. I just found this out tonight from a driver in our club, I do not have an xti myself.
Xray NT1 - Xray T4 2013 TC - Xray T4 2013 VTA - CRCgenX10 - CRCgenX - CRCgenXi - Slash 4X4 with LCG conversion -Associated RC8Be - Xray XB4 - DX3R PRO
Recycled teenager.
www.irocc.ca ; www.corvictoria.com ; http://www.wcics.ca/
I will not send Pay Pal as a gift or add fees to the price so DO NOT ASK!
BCbud is offline   Reply With Quote
Old 03-03-2013, 01:42 PM   #1002
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
Default CRC Team Set-Ups
Questions for the CRC Team - any updates on .pdf set-ups from the CRC Team after the recent National events? (would love to have some udated info. based on the recent success of the team drivers).
Thanks in advance
madjack is offline   Reply With Quote
Old 03-04-2013, 08:47 AM   #1003
tdu verney's Avatar
Thumbs up
I've had issues with two rear pod plates. I think the cause was more self inflicted. You can only hit the boards so many times. Overall I like the car, first CRC I've ever owned.
Old 03-04-2013, 10:00 AM   #1004
Thanks in advance
what kind of setup are you looking for and for which car?
Old 03-04-2013, 06:48 PM   #1005
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
Personally a inline 10.5 blinky setup on a European style track.. would be really helpful
Team losi racing // v-dezign // black diamond
Me_MrTyson is offline   Reply With Quote
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 567 11-20-2017 04:06 PM
