Team CRC Xti 1/12th Scale!! >
Like Tree145Likes
Old 10-17-2012, 05:58 AM
  #301
howardcano's Avatar
Trader Rating: 37 (100%+)
Originally Posted by Tim3 View Post
could these servos work?
Be careful with anything called "Micro". Most of these have a smaller output shaft, and there are no servo savers that will fit.
howardcano is offline
Old 10-17-2012, 06:00 AM
  #302
howardcano's Avatar
Originally Posted by Mark Erce View Post
does anyone here have any experince with the Hitec HS-225MG servo?
I have two HS-225MG servos. Both are painfully slow. I ended up putting one in my oval car where the speed was less of an issue.
Old 10-17-2012, 06:12 AM
  #303
Originally Posted by linkless View Post
I am using the Airtronics 94761Z High Speed High Torque Micro Digital Servo (copy and paste).
For those that are running this servo, are you using a rx pack or a 1S compatible speedo?
The 4.8V specs don't look all that impressive. And I was under the impression that most 1S speedos only output ~5V for the peripheral components?
JamesL_71 is offline
Old 10-17-2012, 06:32 AM
  #304
Originally Posted by b_recliner View Post
What is the timeframe on the xt to xti conversion kits?
Part # 3213. They are on the website. Order one up.
dumper is offline
Old 10-17-2012, 07:24 AM
  #305
Trader Rating: 38 (100%+)
I am using a 1s ESC (Speed Passion 2.1EX) in mine and the servo seems plenty fast and strong. The spec looks to be a bit slow at 4.8v (.15s/60 degrees) but mine looks to be plenty fast and strong.
linkless is offline
Old 10-17-2012, 08:15 AM
  #306
b_recliner's Avatar
Trader Rating: 22 (100%+)
Thank you dumper!! Order will be placed within the week!!
b_recliner is offline
Old 10-17-2012, 08:16 AM
  #307
Csaari77's Avatar
Trader Rating: 34 (100%+)
Is there an ETA on the diffuser?
Csaari77 is offline
Old 10-17-2012, 08:33 AM
  #308
smyka's Avatar
i ran servo at vegas with a 1 s viper speedo no reciever pack no issues servo plenty fast and dialed size for this car
smyka is offline
Old 10-17-2012, 08:48 AM
  #309
Trader Rating: 60 (100%+)
We need front ride height adjusters first.
MC112b is offline
Old 10-17-2012, 09:01 AM
  #310
AdrianM's Avatar
Has anyone tried the Airtronics 94815? I was listed above. It the same size as the 94761 but it is A LOT faster. The torque is a little low by modern standards but I think it would be plenty. When I started racing I used a Futaba S-32 mini servo in my RC10L that had about the same torque and it did fine for years of 6 cell Stock racing.
Here are the specs again:
• Torque at 4.8v: 21oz-in (1.5kg-cm)
• Torque at 6.0v: 25oz-in (1.8kg-cm)
• Speed at 4.8v: 0.07sec/60
• Speed at 6.0v: 0.06sec/60
• Weight: 0.68oz (19.2g)
• Dimensions: 1.16 x 0.47 x 1.02in (29.5 x 12.0 x 26.0mm)
• Gear Train: Metal
• Bushing/Ball Bearing: Single Ball Bearing
• Motor Type: Standard 3-Pole
AdrianM is offline
Old 10-17-2012, 09:47 AM
  #311
Get the swana 94761Z. It will be the most convenient. The screws actually thread into the little wings, don't need to use a nut. The servo is a straight bold on right out of the package.
malkiy is offline
Old 10-17-2012, 10:23 AM
  #312
theatriks's Avatar
Does anybody know what size the front wheel bearings are on the xti
theatriks is offline
Old 10-17-2012, 10:36 AM
  #313
1/8th by 5/16ths
InspGadgt is offline
Old 10-17-2012, 10:49 AM
  #314
theatriks's Avatar
Originally Posted by InspGadgt View Post
1/8th by 5/16ths
Thanks !
Old 10-17-2012, 10:57 AM
  #315
Andrew Knapp's Avatar
1/8th in just like.the xi
Andrew Knapp is offline
