Team CRC Xti 1/12th Scale!! >
Like Tree145Likes
Old 02-18-2020, 04:46 AM
  #2746
WIITA's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Race19s View Post
Circles L & R? If it steers 20 Degrees left and 10 right, itll do the same
This is the first thing I would check for sure. I make sure my circles are the same at the beginning of every race day. Also, depending on what carpet your running on, glue is normally the second thing I would suggest checking. After that, camber, king pins (bent) or the lack of free movement in the front end could cause this as well. Take the front springs off and make sure the kingpin drops through with no bind under its own weight. Other than that, make sure the car goes on a tweak station before every run.
Val214 likes this.
WIITA is offline
Old 02-18-2020, 01:51 PM
  #2747
tim fry's Avatar
Cheers for the pointers.
tim fry is offline
Old 02-18-2020, 03:29 PM
  #2748
h
I had someone help me with my 1/12. They said circles aren't necessary after he adjusted the steering angles on both sides to 18 degrees on both left and right..
The droop thing is what confuses me.
CoryRC is offline
Old 02-19-2020, 06:06 AM
  #2749
WIITA's Avatar
Originally Posted by CoryRC View Post
h
Two ways to do circles, on the track against a board or on a setup station. Both achieve the same thing IMO. Most new drivers donít have a setup station, so doing a half circle each way off the same board and marking that spot will work just as well.
I measure front droop with the amount of sag on the front end at static ride height. Obviously, both should be the same on each side. I tend to run just enough to see that they are both equal on each side. Maybe 1/2mm on each side.
I always run the rear pod level or just a little lower in the front (.2mm). From that measurement in the front of pod, pull up on the top of the shock mount and measure again. Thatís your rear droop setting.
hope this makes sense😂
WIITA is offline
Old 02-19-2020, 09:45 AM
  #2750
Trader Rating: 21 (100%+)
I had tweak in my car for almost 2 months and it wasnt until this weekend i realized it was a collapsed spring. I swapped it out and voila the car was fixed. I went thru droop, a busted rear carbon plate (which i didnt realize was busted) and installed that back square, put it on a statiom, which im trying to get away from and it was still screwed up. Wasnt until i checked the front springs was my problem fixed. After that i swapped out both front and sides and car was good.
i tend to just leave my springs in for a long time. Ill clean the front end and reinstall the old springs but now i know to swap them out more frequently
WIITA likes this.
phatboislim is offline
Old 02-19-2020, 09:50 AM
  #2751
Trader Rating: 17 (100%+)
Any time you take them off the car you should measure them and make sure things are still at least fairly consistent. It's good advice for everyone.
WIITA, Juniorabca and antlockyer like this.
Kave is offline
Old 02-19-2020, 10:05 AM
  #2752
yea now I know lol. If you ask vafactor i have some pretty pathetic practices when it comes to 12th scale. Im working on getting rid of them
Old 02-20-2020, 12:03 PM
  #2753
Trader Rating: 1 (60%+)
Ok so I had a large race this past weekend and completely blew it! OMG so after over viewing my set-up I have some questions. So by rasing the tubes on the outside by 4mm and putting 10k in the tubes what have a caused the car to do with .45 side springs and black center spring with 35 wt losi shock oil. Also glue on the front tires can you all show me how you are cluing your tires...off to the track at this point cause Im pissed how bad I f'ed up...
racer034life is offline
Old 02-20-2020, 01:41 PM
  #2754
Itís likely that your carís poor handling was mostly a problem with tires, usually the fronts. Hereís my take: Raising the outer end of the tubes is such a subtle adjustment that only the most sensitive drivers can even feel any difference from doing so. 10K is a little light in the tubes but not that far off. Suggest sticking with either 15 or 20K. 35 in the shock is also close. I always stick with the kit oil, which I think is 30. And I also wonder why guys vary from the kit side springs (which I think are 50s) and especially the kit red shock spring, which most of the team guys run almost all the time. It puzzles me why do so many guys try to fix what ainít broke. The pure kit setup works so well for most conditions that, unless you really know what you are looking for and how to get it, itís probably advisable to run the CRC car just about box stock. And now to the tires.... for black carpet when the grip is up, itís a must to CA the outer front sidewalls and also to run the tires fairly small. By small I mean not more than 40.5mm up front. 41mm max. What I do is pre-true the tires to about 1/2mm larger than my desired size, ease the edges SLIGHTLY, apply the CA all the way up on the outer sidewalls, let it air dry, spin the tires on the truer and LIGHTLY sand the CAd surface just enough to smooth out the rough pebbly surface, apply a 2nd light coat of CA, let it air dry again, and then skim the tires to my desired race size. This admittedly cumbersome 2 step gluing process works a treat as it yields very consistent front tires that stay good thru many runs. And the last tip if you are having trouble......sauce just the inner 1/2 max of the fronts right before you run and DO NOT let the sauce sit on the front tires for any length of time. Wipe it off right away and then go thru tech and right out to the track. Hope these recommendations help.
davidl and WIITA like this.
vafactor is offline
Old 02-20-2020, 02:59 PM
  #2755
purplerain's Avatar
I disagree with the idea that only the red spring should be used. On a tight track, jumping up to a green allows the rear end to rotate just a little quicker. Also, for any new CRC drivers, the manual for the Gen-Xi has a helpful tuning guide in the back that clearly explains what most setup changes do. Why CRC didnít put this in the CK25ís (crappy) printer paper manuals is beyond me.
purplerain is offline
Old 02-22-2020, 09:47 AM
  #2756
Hey guys. I had a few people ask about my snowbirds setup.
Here she is:
Front:
.50 .25mm droop
3.2mm RH
5* blocks with 2 shims forward
39.7mm tire w/ edges glued all the way up.
-.5 camber
1* toe out
166 front width
Rear:
.50 springs just touching and tweaked dead.
Asc gold center spring
Kit oil
1.5mm pod droop
50k in one tube
Extended top plate with standard shock
172mm rear
41mm tire (canam) normally run 40mm
Battery back
Black art 09 body form CRC
lmk if I forgot something
I can't find the 50Ktube lube, crc only makes 30,000, 20,000, 10,000, and 5,000.
CoryRC is offline
Old 02-22-2020, 10:31 AM
  #2757
LonnyJ1950's Avatar
Choose your weight from the drop down menu
https://www.amainhobbies.com/kyosho-...p453217?v=4382
LonnyJ1950 is offline
Old 03-03-2020, 04:25 PM
  #2758
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Any one have a chart how CRC encore springs compare in rate to Associated VCS springs.
I have a zillion 1/12 small bore springs really don't want to buy another set.
Jamie
J.Gonzalez is offline
Old 03-04-2020, 08:42 AM
  #2759
DesertRat's Avatar
Jamie
Its not up to date but this old chart from Petit RC may be useful:
https://www.yumpu.com/en/document/re...turer-petit-rc
DesertRat is offline
Old 07-04-2020, 01:27 PM
  #2760
mocrawlin's Avatar
Trader Rating: 23 (100%+)
I am looking for an Xi manual. If anyone has one they can email me copy of I would gladly pay for your time.
I need the part numbers in it to get parts ordered for my car Monday. Have a trophy race next Friday and my rear lower pod plate is tweaked and canít get it flat again.
mocrawlin is offline
