Team CRC Xti 1/12th Scale!! >
Like Tree145Likes
Old 11-17-2019, 12:57 PM
  #2716
Originally Posted by tim fry View Post
Yes it can if with the top plate from the old xti.
Not seen it run like this but the original promo showed it as an option
Hmm, I don't see the mounting holes in the main chassis required to mount the Xti upper plate... is there a special option servo plate with shock extension or something?
DavidNERODease is offline
Old 11-24-2019, 02:15 PM
  #2717
Airwave's Avatar
Does anybody know where to find a Black-Art conversion for Xti? Or at least the chassis?
Airwave is offline
Old 11-24-2019, 02:27 PM
  #2718
tim fry's Avatar
I have one if interested? I don't think they are for sale currently
tim fry is offline
Old 11-27-2019, 06:09 AM
  #2719
Airwave's Avatar
In which condition? new? used? price?
Airwave is offline
Old 11-27-2019, 11:28 AM
  #2720
tim fry's Avatar
Used but perfect. Can email pictures if interested. Please PM me your details.
tim fry is offline
Old 11-27-2019, 04:58 PM
  #2721
What kind of polishing compound do you use for the kingpin? If any.
JOE SI is offline
Old 11-27-2019, 08:36 PM
  #2722
Zerodefect's Avatar
Turtle Wax Chrome Polish. Dremel with a hard cotton disk.
JOE SI likes this.
Zerodefect is offline
Old 12-01-2019, 01:09 PM
  #2723
Eagle One Nevr-Dull Wadding Metal Polish
K.Kincaid is offline
Old 12-01-2019, 09:07 PM
  #2724
two shoes's Avatar
Trader Rating: 21 (100%+)
Flitz
two shoes is offline
Old 12-03-2019, 02:53 AM
  #2725
Metal polish, paper towel and a beer....beer is for me
JOE SI likes this.
phatboislim is offline
Old 12-30-2019, 07:22 PM
  #2726
Trader Rating: 1 (60%+)
So my current 17.5 open 1/12 ck25 likes to spin out at low speed if i get of the throttle to much. Does anyone have a general idea of what could be causing this issue and what do I need to do to correct this issue. I am currently running a locker at the rear. running a lola blackart body and kit set-up with 1.5 mm pod droop. long arm front-end conversion stock chassis.
racer034life is offline
Old 01-01-2020, 06:11 AM
  #2727
Zerodefect's Avatar
Too much droop. Not enough roll center spacer on the front. Too much tweak preload or spring stiffness.
Old 01-01-2020, 06:40 AM
  #2728
Sounds like a tire issue since the CK25 kit setup is usually very good for most conditions and using the long arms tends to forefit steering and make the car less aggressive. If you aren’t already glueing your front tire outer sidewalls, that’s a must on black carpet. Also letting the tire sauce sit on the fronts too long will cause oversteer.
racer034life likes this.
vafactor is offline
Old 01-01-2020, 06:49 AM
  #2729
Two other things to check are to first make sure your pod’s side to side action is nice and free, especially the adjustment of the center pivot ball so that there’s no bind and no “click” as described in the manual. And of course both front arms must also move freely...free enough so that when the front springs are removed, and you lift up each front arm, the assembly will drop just by its own weight.
vafactor is offline
Old 01-01-2020, 12:58 PM
  #2730
.45 front crc springs, and .50 linar side springs with kit oil in shock and purple spring on the center. The car is great from center off, but going into a slow speed 180 the car will lift the outside wheel to much, ( that can be my trigger finger also), but outside of these issues my crc ck25 car feels amazing. Also does Mcfactory still make chassis? If so I would like to try one.
