Team CRC Xti 1/12th Scale!! >
Like Tree145Likes
Old 01-15-2019, 11:04 AM
  #2626
Trader Rating: 46 (100%+)
Wow! a $330 CRC 1/12th scale...
Looks pretty good.
https://www.teamcrc.com/crc/modules....rticle&sid=238
Buckland and MPisterzi like this.
biz77 is offline
Old 01-15-2019, 02:40 PM
  #2627
MPisterzi's Avatar
Trader Rating: 25 (100%+)
Looks pretty good.
I miss 1/12!
MPisterzi is offline
Old 01-15-2019, 02:45 PM
  #2628
Default Make it happen in Boise!
Originally Posted by MPisterzi View Post
I miss 1/12!
Surely there's enough people interested in Boise to do a winter on-road program with 6-10 races per year?
biz77 is offline
Old 01-15-2019, 02:50 PM
  #2629
MPisterzi's Avatar
I've asked around, not a big following here. From what I've been told it been tried a few different times but soon after falls out of favor. Indoor offroad on carpet is all the rage here now, it's fun but nothing like 1/12 racing. I'm hoping to get up there once this season for a race.
Old 01-15-2019, 03:53 PM
  #2630
If you order it like I did and add the chassis and the rest of the parts it was more than that. The car works very good on Black carpet as most of the racers in our new class GT12 USA are running different forms of the CRC chassis.
BullFrog is offline
Old 01-17-2019, 03:04 PM
  #2631
Any consensus on standard mounting versus over axle mounting of the Sanwa SRG-HR servo?
biz77 is offline
Old 01-17-2019, 03:38 PM
  #2632
RussF's Avatar
Trader Rating: 21 (100%+)
Questions about gearing ratio. I'm currently running 49/72 gearing on my CK25, GT12 class. That gear ratio is 1.47. Is it "better" to run larger gears with a similar ratio? Or is the ratio all that matters? I was considering if something like 55/80 would be better. I purposefully left out tire diameter as I'm not figuring rollout. Just a general question about gearing ratio.
Also is there a better brand spur gear to use? I currently use the CRC brand spur and pinion with 2.5mm balls included with kit. I added the CRC lightened diff rings.
RussF is offline
Old 01-17-2019, 04:17 PM
  #2633
Going to larger gears for the same overall ratio will increase overall mass (albeit a very small increase) as well as increase rotational mass. Larger overall gears will however move the heaviest part of the pod (the motor) closer to the pivot point, which is generally a good thing.
I'm not a fan of the CRC 3/32" ball spur gears. They have never been nearly as smooth as a 12-ball 1/8" gear for me and I've had binding issues with the lip they use where the bearing fits into the spur. I currently use Axon spurs in stock class, but have had good luck in the past with PRS, Xenon (16-ball 1/8") and RW spur gears as well.
biz77 is offline
Old 01-17-2019, 10:38 PM
  #2634
am
Hi, anyone using a thrustbearing in te diffassembly for the CK25?
am is offline
Old 01-18-2019, 08:24 AM
  #2635
Spur gears- Kimbrough.I've used them for many years.I even made a Kimbrough spur gear to work on my xray grear diff. Been using it for several weeks and it works fine.
We run 57-59x76 with our GT12 class.
BullFrog is offline
Old 01-18-2019, 08:48 AM
  #2636
Super Moderator
Marcos.J's Avatar
Trader Rating: 211 (100%+)
thatís what I have on my CRC 57/76
hey Bill got it ready for you lol
Marcos.J is offline
Old 01-18-2019, 02:26 PM
  #2637
U racing this weekend at 386? Looks good.
BullFrog is offline
Old 01-18-2019, 04:07 PM
  #2638
Super Moderator
Marcos.J's Avatar
deans has birds layout and itís pretty much same size Iíll may be up there next week
Marcos.J is offline
Old 01-18-2019, 05:09 PM
  #2639
Airwave's Avatar
I've always been curious about these bodies... The front seems to be as large as lola bodies, but what kind of tyres are you using in the rear? Same as "lola" 1/12th or specific narrower tyres?
Airwave is offline
Old 01-19-2019, 07:21 AM
  #2640
Super Moderator
Marcos.J's Avatar
crc spec tires with the purple ring
Marcos.J is offline
