Team CRC Xti 1/12th Scale!!
#2491
Hey guys, having a little issue with my new to me xti alter ego. On black carpet the rear of the car is just glued to the track and I'd like to free it up a bit. It feels like I'm just scrubbing speed quite a bit in the corners. I've been using ulti medium tires but the track will be switching to purple specs shortly, I was told they are a bit softer than the ultis so I'd imagine thats going to make the issue a little worse. I am running white side springs, 30k tube lube, red center spring with 30 wt oil. Any suggestions? - Thanks
#2493
Do you have any others? An easy fix is a body swap(if you have them), so you can determine if its an aero thing, or a setup thing. Strakka or the CRC Lola would free up the back if its aero tight. The other thing I would for sure do is get an AE Blue or Gold center spring. The CRC stock red is pretty soft.
#2494
#2495
#2496
Your shock and side spring choices are good. Tube lube could be a little thick however. For me, 15K typically works best under nearly all track conditions. Easy way to find out.......run some laps with your 30k to get a feel of the car, then make a quick pitstop and pop off just one of the tubes, and run a few more laps with just one tube connected. If the car improves, that's proof that your tube lube is too thick. And if not, then something else is causing your issue. Another thing......on black carpet guys at our track have been running full or almost full front sauce. In times past, running that much sauce on the front tires was completely taboo. But nowadays with the black carpet it often works well. And if you decide to try full front sauce, make sure that your sidewalls are glued and don't let the sauce soak for more than a minute or two. Hopefully one (or maybe both) of these suggestions helps.
#2497
In my opinion, "free up the car" on spec tires usually means less efficiency. Your issue with scrubbing speed in corners can usually be remedied by front end tuning, usually by a combination of softer front springs, trying a few different combinations of caster/reactive caster or camber/reactive camber. A lot of the time having the back "follow the front" instead of pivoting on the nose allows more aggression and better lap times.
#2498
i don't race carpet, (asphalt med traction), the BMR if your track has med to high traction in a 17.5 spec class imo....is too much. in spec rear end is too planted, and you get twitching on rear sorta a grab then give thru the turns which fights your front end. AMR is a good inbetween choice, the strakka and lola are slicker (less downforce/drag) and faster
#2499
I have a couple of questions. The first one is what is the tube lube that comes with the kit? It came in a little packet and seems to work well but doesn't look like 10k.
The second question. Is there a way to remove the cells without popping off the shock each time? I have always done it that way but it creates extra wear in the shock ball cups
Cheers
Cheers
#2500
Cheers
Cheers
One thing that I have done so that I don't have to take the shock off is to either run the long shock adaptor and add a shim or two under both the front and read of the shock under the ball end.
Jon
#2501
Subscribed
#2502
If this is for the new CK25 kit I think that is 20k for the tubes that comes standard.
Jon
Jon
#2503
i think 10k is kit
Question: How often do you guys replace the 'football' center pivot plastic pieces?
#2504
Cheers
Cheers
#2505
