Team CRC Xti 1/12th Scale!!
#2146
Shock o ring
I bought a new encore shock to make tuning at the track easier. Even though I lubed the shaft and went slowly I still managed to tear the o ring. Does anybody sell just the o rings? Are they the same as associated?
#2147
Click on link below for the part info.
Calandra Racing Concepts Inc.
Would not surprise me at all that CRC would just mail you one. Good guys there. Or, PM me your address; and, I will mail one from my spares on Monday.
Bill
#2148
gm,
Bill
Bill
#2149
Has anyone had any issues with the new duel clamping hub?
Mine doesn't seem true so my left wheel wobbles now..
#2153
Otherwise, speaking from my experience with the dual clamping left hub used on my CRC WGT/WGT-R cars...I found that it was best to tighten them up a little at a time and alternate back and forth between the two screws to achieve an even amount of tension to grip the axle. Thinking that this may apply to your 1/12th scale hub too.
Because Dumper (Brian Wynn) has not chimed in yet. He may have more input. Or, contact him directly at CRC ([email protected]).
Hope this helps!
Bill
#2154
Gray carpet setup
Anyone have a good gray old carpet setup? Kave posted a setup for black carpet, so I'm not sure how much of that I can apply. I assume I have a lot less traction.
#2155
Have you raced much 1/12? This class, more than probably any other, is a case of trying to start with the kit setup and find what you can drive well. Tires are the most important, I would start with a set of CRC blue rear and double blue front or Ulti X-medium rear and X-hard front. Cut them to 41mm front, 41.5 rear, set ride height, and with just the kit setup it should work fairly well.
#2156
It's not a LOT less traction, but maybe a bit.
It's been a few years. I've been running about 2 months now. Lap times are getting pretty consistent. I was trying to use up older tires but it's not working out. Car is faster and cuts better on purple specs (only tire stocked at the track). Class is 17.5 blinky
#2157
also running a stiffened carbon chassis seeing how i like it versus the AL i was running.
Spec Tires at 41.5 all the way around
3.5mm RH all the way around
.45 front springs (looking to stiffen this up on high grip carpet to .50 soon)
2 shims back
5* caster block
40wt center shock oil
Associated gold center spring
1mm pod droop
.50 side springs
20k side lube
the track i ended up running on 72/56 on 41.5 tires w/ a one model old team scream racing The One 17.5. 15* on the can
i ran full sauce front and rear. best sauce timing about 15 minutes.
#2158
I wish our track would use the purple stripes as the only tire in 17.5 blinky 1/12. I'm so tired of buying different tires to try, just to have a bunch of tires I cant use and a bunch of money spent. Our track has gray "office" type carpet. We run offroad on the same track so the carpet needs to be tougher. I would call traction medium low to start and gets better throughout the day. For a setup I use the .45 side springs, .60 front springs, green center spring, 30 wt shock oil, 15k side lube, 1mm pod droop, .5 mm front droop. Right now I am changing the front end to the 0* blocks (was 5*) with two shims forward (was 2 shims back) to see if I can get rid of some mid corner oversteer. I always have too much steering and never enough rear grip. Tires I like are the Black fronts with Yellow rears or Contact 35 front and 28 rear. I just bought some softer rear tires to try. Probably another waste of money though. I'd rather concentrate on setup rather than tire selection would love it if the track would spec the purple stripes or some other combo.
#2159
#2160
Thanks for the setups. I will give these a try. Trying to run down some xrays. I'm in the minority running CRC.
