Team CRC Xti 1/12th Scale!! >
Like Tree145Likes
Old 01-17-2017, 04:58 AM
  #2131
Trader Rating: 21 (100%+)
random, but is there an upgrade over the plastic center pivot? part no. #3374
phatboislim is offline
Old 01-17-2017, 05:18 AM
  #2132
I
C&M Motorsports made a nice delrin pivot with the same spacing as CRC, but I don't think they're around anymore.
Serzoni is offline
Old 01-17-2017, 09:58 AM
  #2133
Heathen's Avatar
Originally Posted by Kave View Post
It's been quite some time since the team posted a setup for people to try so I figured I would post what several of us have been running as of late for people try. This is the setup we most recently ran on a high speed tight track at the Hudy Race in St. Louis. If your track is on the new CRC Black Carpet and you are looking for something that reacts quickly, especially through the tighter sections of the track I would strongly recommend trying this.
Front:
.45 front springs
.25-.5mm front droop
5degree castor blocks
2 shims back
.25deg camber
2.5mm roll center shim
Losi Smart Diff Grease on the kingpins
Brass pivot balls
Ballstuds on steering knuckles shimmed up 2.5mm
(Make sure that the turnbuckles are level and that they are parallel to the front of the chassis or have a slight forward sweep)
166mm front width
CRC Purple Stripe - 39.5-40mm
Rear:
35wt shock oil
AE blue or NEW crc purple center spring
.50mm of spacing under the front side link
.50 CRC side springs - outboard position
2mm pod up-travel
15,000wt diff fluid in the tubes (can use 1 tube of 10k and 1 tube of 20k as an option)
172mm rear width
CRC Purple Stripe - 40-40.5mm
CRC Audi R8 Body in 17.5
CRC Lola Body in 13.5
Option Parts:
New CRC LCG Rear Pod
New CRC Double Clamping Hub
New CRC Dampener Tube Ballstuds
If anyone has any questions about this setup I would be more then willing to answer, just let me know either on here or on Facebook.
What is the part number for the new damper tube ball studs?
Are they for the inner or outer ball studs?
Heathen is offline
Old 01-17-2017, 11:14 AM
  #2134
Trader Rating: 17 (100%+)
This is what you want. http://www.teamcrc.com/crc/modules.p...prodID=7719748
It's the inner studs.
Kave is offline
Old 01-21-2017, 11:33 AM
  #2135
valk's Avatar
Default Mip tools
Not sure if anyone has noticed but mip is trying to presell 250 sae nut driver sets to secure a production run. Anyone who has a crc should preorder it as it comes with all the nut drivers we use and no one can argue the quality of mip tools. The preorder price is $40 for the three vs $18 each if they ever do get made.
But get on it. Ive wanted mip nut drivers forever!
valk is offline
Old 01-24-2017, 08:38 AM
  #2136
Default New pod plates - lighter?
Can someone who has one of the new lowered slider pods please comment on how much it weighs as compared to the original style of slider pod?
vafactor is offline
Old 01-24-2017, 09:51 AM
  #2137
Mine was 2g heavier than the stock pod.
Serzoni is offline
Old 01-24-2017, 09:55 AM
  #2138
Hey guys, I've added some adapters to my Shapeways shop that will allow you to measure the caster angle on the CRC front end with most setup systems on the market. The adapters sit on top of the steering blocks and hold a short piece of 1/16" music wire. The wire will point to the markings located on most setup systems such as Hudy, Trackstar, etc.. No more eyeballing the caster angle. There are two holes for mounting the wire, so these work with both inline and trailing axles, and fit both the original pro-strut steering blocks, as well as the newer blocks for the 1/18" axles.
https://www.shapeways.com/product/NG...aster-adapters
Attached Thumbnails Team CRC Xti 1/12th Scale!!-3.jpg   Team CRC Xti 1/12th Scale!!-2.jpg   Team CRC Xti 1/12th Scale!!-1.jpg
Serzoni is offline
Old 01-24-2017, 05:07 PM
  #2139
Pretty cool.
chad508 is offline
Old 02-06-2017, 07:55 AM
  #2140
gmintimidator's Avatar
Is the new lcg pod available at any online retailers or only through crc? I couldn't find it on amains website.
gmintimidator is offline
Old 02-06-2017, 07:58 AM
  #2141
I bought mine from Stormer
Serzoni is offline
Old 02-06-2017, 08:51 AM
  #2142
Also Horizon hobby
blankenj99 is offline
Old 02-06-2017, 10:12 AM
  #2143
Thanks for the info.
Old 02-28-2017, 08:38 AM
  #2144
performula's Avatar
I think it's "kinda" verified, but will a Futaba S9650 Servo fit the XTI WC, stock, without any modifications/drilling?
performula is offline
Old 02-28-2017, 10:01 AM
  #2145
Trader Rating: 46 (100%+)
In the standard position behind the front axle. Not in front of the front axle like the ultra small Sanwa SRG-HR without cutting ears off and shoe gooing.
biz77 is offline
