Team CRC Xti 1/12th Scale!! >
Like Tree145Likes
Old 01-09-2017, 09:23 AM
  #2116
Trader Rating: 21 (100%+)
Originally Posted by Radi0Flyer View Post
Thanks guys, I'll have another look at it. The instructions indeed show the balls facing forward but it also shows a regular size servo. With this little servo I managed to use at least one of the original servo mounts but if I flip the balls I will have to drill a few new holes to move the mounts back a bit. One of them might end up too close or interfering with the servo saver cut-out.
Sean
Just in case you're interested, i have a stock XTI-WC Chassis for sale
phatboislim is offline
Old 01-09-2017, 09:32 AM
  #2117
Radi0Flyer's Avatar
Thanks Slim but I'm good with this thing.
Sean
Radi0Flyer is offline
Old 01-09-2017, 09:44 AM
  #2118
Radi0Flyer's Avatar
And here it is...
https://youtu.be/MiCv9tUceYs
My embed-fu doesn't seem to be working tonight.
Sean
Also, Turnigy has the TGY-211DMH servo which is identical in size to the 212 and also has a Futaba 25 spline output. It's half as fast but almost twice the torque. (just a bit less than a standard Futaba S3003 servo)
I don't think it's really fast enough for a 1/12 pan car but I mention it because it's a direct fit replacement for the Traxxas 2065 servos that are used in the 1/10th Summit for shifting the transmission and locking the diffs. It has the same torque as the Traxxas 2065 but is twice the speed. It has metal gears and works great in the Summit. (either the 211 or 212 will work fine) They don't advertise them as being waterproof but I get my Summit pretty wet and it's holding up sofar.
Sean
Old 01-09-2017, 10:09 AM
  #2119
Sean
Old 01-09-2017, 08:22 PM
  #2120
Originally Posted by 1/8 IC Fan View Post
Post # 2087
I'm still running a Turnigy TGY-212DMH. It has been in the car since new and has never been replaced. It's been hammered a bit but is holding up. It isn't as powerful as some of the other options but it is stronger than my servo saver and it's lightning quick. It also uses a regular size Futaba 25 spline drive.
Thank you 1/8 IC Fan and Radi0Flyer for the information on this servo.. Might be something to look into if a friend and I need new servos in the future..
Jon
Juniorabca is offline
Old 01-10-2017, 05:02 AM
  #2121
Fredp1's Avatar
Another servo to look at is the TrackStar TS-P12S servo. It's a reliable and fast servo.
Fredp1 is offline
Old 01-10-2017, 07:17 AM
  #2122
Radi0Flyer's Avatar
I have to admit to being a bit of a servo junkie. That one has been on my wishlist for a while now but never got one to try out. I think I have a Tamiya F1 that needs a servo...
Sean
Old 01-11-2017, 09:50 AM
  #2123
Trader Rating: 17 (100%+)
It's been quite some time since the team posted a setup for people to try so I figured I would post what several of us have been running as of late for people try. This is the setup we most recently ran on a high speed tight track at the Hudy Race in St. Louis. If your track is on the new CRC Black Carpet and you are looking for something that reacts quickly, especially through the tighter sections of the track I would strongly recommend trying this.
Front:
.45 front springs
.25-.5mm front droop
5degree castor blocks
2 shims back
.25deg camber
2.5mm roll center shim
Losi Smart Diff Grease on the kingpins
Brass pivot balls
Ballstuds on steering knuckles shimmed up 2.5mm
(Make sure that the turnbuckles are level and that they are parallel to the front of the chassis or have a slight forward sweep)
166mm front width
CRC Purple Stripe - 39.5-40mm
Rear:
35wt shock oil
AE blue or NEW crc purple center spring
.50mm of spacing under the front side link
.50 CRC side springs - outboard position
2mm pod up-travel
15,000wt diff fluid in the tubes (can use 1 tube of 10k and 1 tube of 20k as an option)
172mm rear width
CRC Purple Stripe - 40-40.5mm
CRC Audi R8 Body in 17.5
CRC Lola Body in 13.5
Option Parts:
New CRC LCG Rear Pod
New CRC Double Clamping Hub
New CRC Dampener Tube Ballstuds
If anyone has any questions about this setup I would be more then willing to answer, just let me know either on here or on Facebook.
Kave is offline
Old 01-11-2017, 02:48 PM
  #2124
Airwave's Avatar
And here it is...
Sean
If you use double-face tape or shoe goo, you should add a small spacer under the servo support, it seems that it is not horizontal...
Airwave is offline
Old 01-11-2017, 03:03 PM
  #2125
Radi0Flyer's Avatar
Yeah it's a bit off. It was one of those "It ain't broke so don't fix it" kind of things.
I'm just going to move the servo back a bit and use both mounts I think.
Sean
Old 01-11-2017, 07:40 PM
  #2126
Front:
.45 front springs
2 shims back
.25deg camber
Brass pivot balls
166mm front width
Rear:
35wt shock oil
2mm pod up-travel
172mm rear width
Option Parts:
Please provide details around the .5mm shim under the front link mount. Does this involve rear-steer?
davidl is online now
Old 01-11-2017, 08:21 PM
  #2127
That would be correct. It's not going to give you more steering but it will help the car get through the corner a little easier. Some people have been running even larger shims but I think the car has enough rotation that by adding .5mm we are able to keep a very neutral feel.
Kave is offline
Old 01-12-2017, 11:46 AM
  #2128
tdu verney's Avatar
Default Prolevelrc
Kave,
Did you use a roll center shim?
tdu verney is offline
Old 01-12-2017, 12:54 PM
  #2129
Originally Posted by tdu verney View Post
Kave,
I did run a roll center shim, thanks for pointing out that I forgot to add that! The roll center shim really doesn't take away steering it's just going to make the feel much more linear as it reduces the camber gain to reduce that sharp hook mid corner.
Kave is offline
Old 01-12-2017, 09:22 PM
  #2130
Goof's Avatar
Trader Rating: 75 (99%+)
Originally Posted by Outlaw 44 View Post
Also, if I were to run this car in Blinky 17.5, which of the two speed controls I own would be better suited for this car? Castle Mamba 1s or Tekin RS Pro?
I like the gen2 trackstar 1cell. tekin rspro should work but might need a booster .. Is the mamba sensored
Goof is offline
