Team CRC Xti 1/12th Scale!!
#2073
I had a decent outing from my Xti inline car over the weekend, considering that it was basically a new car with one practice day I think that with a little more time and a better battery/motor combo it could have been quite competitive in the 13.5 class I was running.
Because it was pretty good off the bat, I think the chassis deserves some effort and my first problem is that I would like to find a better servo. I am running the old Airtronics micro servo that bolts directly to the chassis, and its getting pretty crunchy. Has anybody found an appropriate replacement? I wanted to keep it as a micro and not a mini servo that has to be glued into place.
#2075
#2076
I have a question, what is everyone running for servos on the CRC XTI WC?
#2077
I run the JR Z3650 in the "normal" position behind the front axles. I believe the Futaba 9650 and KO Propo RSX12 also drops in this spot. If you want to mount in front of the front axles then I believe the Sanwa SRG-HR or SRG-HS are the only drop-in models. You can make most mini servos fit using shoe goo.
#2078
I run the JR_Z3650. However, my servo is in front of the axles. I did trim the tab.
#2079
#2081
LMAO i was going to get the Roche...this is going to prolong me getting the Roche especially since i was going to keep my CRC anyway
#2083
i would certainly hope that this is standard in their WC kits now as they get rid of their current (or i guess you could say past) kits
#2085
Interested to hear what you think of the new pod, keep us in the loop!
