Team CRC Xti 1/12th Scale!!
#2026
Use 2.5 mm balls in CRC spur gears (#1227), they "pop" in and stay in. The diff builds excellent and is WAY lighter than 1/8" balls. Spinning weight reduction... always good.
#2027
guys what am i missing here. I can't get the diff tight. i bought this car used and evidently the rear axle wasn't right. I still haven't found an online manual that shows what i have. Is this right? The cone washer needs to be replaced now since i flattened it trying to get the diff tight. I can figure out what is keeping it from tightening.
#2029
So this is where i am now. The diff will tighten but I'm going to replace the flanged bearing in the hub, because it feels like crap.
#2030
This pic is what took me down this road. Its how the car was delivered. If i could just find a online manual i would tear the car down complexly and rebuild it myself.
#2031
https://www.teamcrc.com/crc/download...rts-final2.pdf
#2032
Pod/Rear axle assembly are basically the same between the WC and standard XTi-
#2033
2 things I can think of that might be causing this. I know Slapmaster makes different thrust bearing kits for different axles. It is possible the one for the 12r5.2 doesn't have a long enough nylon spacer and the nut may be bottoming out on the end of the axle. Or the nut may just be worn out and in need of replacing.
Jon
#2034
Got a new bearing coming and got a new cone washer. Just how tight should the diff be? Should i be able to move the spur or should it be locked down? The only other pan car i had was a RC10L, yes that long ago. By the way i got tired of trying to remember how to calculate roll out and just built a calculator. Let me know if anyone wants a copy
#2036
I have the slapmaster kit with all three spacers so that shouldn't be the problem as I used the one that was closest to just cover the graphite end. I just read later in the thread that they have changed the axle and it doesn't get enough thread engagement using the thrust bearings. I think they have suggested using an older axle. I will look into this and see what I can find out. I really liked how the slapmaster bearing made the diff smooth on my 12r5.2.
Jon
Jon
If you have the older 8-32 stud axle, you can install a thrust kit. If you use 1/8" diff balls, use the #101 kit. If you use 3/32" or 2.5mm diff balls, use the #120 kit.
Brian
#2037
Dude, I was not aware of that. Thank you very much for that... I was so disappointed about running my car without your thrust kit...
I'm gonna recycle my XL axle :-)
#2038
i've heard whispers of CRC working on a new pan car. anyone heard of this? i've only seen them release an aluminum chassis for the WC
#2039
Not sure why CRC would even need to release a new version car considering that Andrew Knapp just swept all of the 1/12th scale classes in Vegas with their existing platform. This with many of the most talented drivers from all around the globe in attendance, so his dominance was certainly no fluke. Oddly, I've not yet seen the usual victory photos and/or setups posted from Andrew's winning ride(s), but I do recall reading somewhere that he was actually running standard graphite chassis plates and not the optional alloy that many consider so advantageous for running on the new black carpet.
