Team CRC Xti 1/12th Scale!! >
Like Tree145Likes
Old 03-19-2015, 12:42 PM
  #1726
ptt
Default Missing threads
Excited to receive my first 1/12 scale pan(XTI WC). Not excited to find missing thread on one side of steering linkage. Really?
img.photobucket.com/albums/v607/pt1824/IMG_1247.jpg
ptt is offline
Old 03-19-2015, 01:03 PM
  #1727
wingracer's Avatar
Trader Rating: 24 (100%+)
Man that sucks but it happens. Pick up some Lunsford titaniums.
wingracer is offline
Old 03-20-2015, 02:39 AM
  #1728
WIITA's Avatar
Trader Rating: 42 (100%+)
Contact CRC and they will get you a new one out right away. Their customer service is second to none.
WIITA is offline
Old 03-23-2015, 01:55 PM
  #1729
ptt
Sent John at CRC an email Friday and he shipped out a new one right away.
ptt is offline
Old 03-23-2015, 06:46 PM
  #1730
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Congrats to BW for the podium finish at 12th Euros!
andrewdoherty is offline
Old 03-26-2015, 02:19 PM
  #1731
DesertRat's Avatar
When you are preparing your CRC Carpet Knife for a race... is that sharpening?
DesertRat is offline
Old 03-26-2015, 02:37 PM
  #1732
Could be Honing
InspGadgt is offline
Old 03-26-2015, 07:31 PM
  #1733
Most definitely! Honing is a process for forming round features in a material.
davidl is offline
Old 03-26-2015, 07:49 PM
  #1734
Not when talking about a blade. Honing a blade is the fine sharpening of a blade as opposed to the initial rough or quick sharpening.
Old 03-26-2015, 08:58 PM
  #1735
DesertRat's Avatar
Well, I think what I'm busy with at the moment is the rough sharpening, trying to get my prep for the Mile High in before the day I was supposed to leave.
I have a good feeling about this race, I think I've found the way my cars want to run if I'm on Ozite and SXT 3, much better than the IIC and that was on blacks and yellows. Anybody sees the car they wonder how it drives at all, it's so soft.
Old 03-27-2015, 04:35 AM
  #1736
.................... Anybody sees the car they wonder how it drives at all, it's so soft.
That should be good for high bite conditions.
davidl is offline
Old 03-27-2015, 01:47 PM
  #1737
DesertRat's Avatar
The front is pretty standard but the rear is the softest springs I could find with thick goo in the side dampers. I even ran a practice with no rear side springs at all in my attempt to keep the rear pod flat on the ground in corners instead of diffing out, but I eventually settled on an ancient 8-pound center spring that dates to the T-bar days and AE 3-pounders for side springs.
Old 03-27-2015, 02:32 PM
  #1738
wingracer's Avatar
If you're diffing out, stiffer front springs can help. Also try lighter on the tubes.
Old 03-27-2015, 04:02 PM
  #1739
DesertRat's Avatar
To be honest I was probably trying to run tires that were a little too big for the grip. I only had one good set and I needed them to last a practice run, two qualifiers, and the main, but when they trued themselves down the car was stuck like superglue. I wish I had run that setup and tire combo in Vegas, it would have easily been a lap faster than I was on yellow/black.
The car ran best with .55's on the front and a full sauce on the front tires, .50's and less sauce didn't hold the corner speed.
Old 03-27-2015, 04:30 PM
  #1740
wingracer's Avatar
Sounds good then. .55s are what I almost always run on high bite. I'll even go .60 for stupid high bite. .50s for old wore out low bite tracks.
