Old 09-10-2012, 08:23 AM   #1
Default Burnt ESC?
Hey guys. I was trying to calibrate my ESC and some smoke ended coming out. I then let it cool down and then tried calibrating it again. I succeeded following the steps, but the fan dies and the servo is still moving. What just happened?
issuzark is offline   Reply With Quote
Old 09-10-2012, 08:26 AM   #2
Most esc's with a fan run the fan on start up but once they see the esc is not hot it will cut the fan off, so they have a temp switch on the fan. Esc should be good if it still runs the motor.
VORRA; www.RVAHobbies.com; www.ashfordhobby.com; www.tqwire.com
bgrick is offline   Reply With Quote
Old 09-10-2012, 08:57 AM   #3
The motor isn't running. But it runs everything else. So basically everything is still programmable, and yada but the motor is not moving.
Old 09-10-2012, 01:13 PM   #4
what ESC ?
Mark Barden .
mb racer is offline   Reply With Quote
Old 09-10-2012, 04:12 PM   #5
Trader Rating: 217 (100%+)
All the ESC runs is the motor. Servo is controlled by the receiver and battery combo. You probably smoked it the way it sounds!
Andy Koback is offline   Reply With Quote
Old 09-10-2012, 07:41 PM   #6
Hobbyking 100A ESC. I think I did too. And I think I now know why. They set the throttle limit to 0%, and I thought I was calibrating it. So I went full throttle (according to the crappy manual), and tada!
Novak Havoc Pro SC ESC Thread litlemac26 Electric Off-Road 452 06-04-2014 10:09 PM
New Xerun 150a/80a esc-motor combo's havatitan Electric Off-Road 1447 07-05-2013 10:16 AM
Burnt ESC autostyle Electric On-Road 32 12-21-2007 02:48 PM
