Old 09-10-2012, 05:39 AM   #1
QYKLSVR's Avatar
Trader Rating: 85 (100%+)
Default Another tell me what car I have
Okay, here I have an HPI chassis, I am just not sure what it is. I have looked numbers times on HPI sections of forums, and even Google images, but have had no luck. It is graphite/carbon chassis/shock towers. sway bars etc. Any insight or info on the car would be great. Also could I put a brushless setup in it? I picked it up cheap, and will give me something to do this winter. Thanks in advance!!
Another tell me what car I have-dscn0055.jpg   Another tell me what car I have-dscn0056.jpg   Another tell me what car I have-dscn0058.jpg   Another tell me what car I have-dscn0057.jpg
QYKLSVR is offline   Reply With Quote
Old 09-10-2012, 06:03 AM   #2
Looks to me like an RS4 Pro, could be wrong but its my best educated guess
moose07 is offline   Reply With Quote
Old 09-10-2012, 06:09 AM   #3
HPI RS4 PRO
Pickthall is offline   Reply With Quote
Old 09-10-2012, 06:15 AM   #4
QYKLSVR's Avatar
Thanks for the replies. Worthy buy for $10? Will it handle brushless power, say Novak Drift spec 18.5t or something?
Also, could u give me some worthy places to buy replacement parts/hop-ups for??
Old 09-10-2012, 06:52 AM   #5
Radio Active's Avatar
First truly modern TC in my opinion. It'll handle it.
Reigning NSW 4WD Group 20 Champion
Member: Maitland Radio Car Club (http://www.morcc.com.au)
twitter: @dvcotton
Australian 12th Scale hastag: #EP12AU
Radio Active is offline   Reply With Quote
Old 09-10-2012, 07:26 AM   #6
alcyon's Avatar
where is the layshaft? it was one of the best if not the best TC of 1997 - 1998. If you are using it for drift, you should have no problems with parts.
http://kawada-alcyon.blogspot.com/
http://superturbooptimamidspecialzx-5.blogspot.com/
kawada sv10 alcyon 3-sanwa mx3x-orca vx v4.1 software-team powers 13.5 motor-turnigy 4200 shorty lipo-savox 1251 servo RIDE RE32
alcyon is offline   Reply With Quote
Old 09-10-2012, 01:37 PM   #7
QYKLSVR's Avatar
I am unsure, as this is the condition I got it in. it was just a parts bin chassis I was lucky enough to snag. Good to know it will take brushless power.
Old 09-10-2012, 02:26 PM   #8
IndyRC_Racer's Avatar
You can download the manual many of the HPI kits directly from HPI from their website (http://www.hpiracing.com/instructions/). I would suggest downloading both the RS/4 Sport and Pro manuals.
The HPI Sport/Pro kits share many parts, but the steering racks are slightly different. Also the PRO kit came with many of the upgrade parts. Both kits can be configured to use a stick pack or saddle pack. I should also mention that those kits share many parts with older HPI nitro cars, so it shouldn't be too difficult to find replacement parts.
One other thing, the Sport/Pro can also be configured as a 190mm or 200mm car. You would use the same a-arms but different dog bones or CVDs - the part numbers will be in the manuals.
One last item, these cars where designed to run brushed motors - which are a small diameter. You may have issues of the rear belt rubbing on a brushless motor when installed. If your car didn't come with a rear belt tensioner, this can help with the belt rub in the rear. Brushless motors also use smaller spurs/larger pinions, which should help with that issue as well. The real issue on these cars is that you adjust the motor up/down for gear mesh.
Hope this info helps.
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 09-10-2012, 03:03 PM   #9
QYKLSVR's Avatar
Indy, Thanks so much for that link! This is my first REAL on-road. I did realize these were designed with brushed motors. Usually 540 sized correct? I will probably drop a VXL-3s from a previous TRX truck in it, which should be smaller, or close to the same size as most brushed motors. So hopefully I wont run into any rubbing issues. It has a rear belt but I will probably replace that along with both diffs, the front seems to wobble a bit anyway. What sort of gearing should I start with. I dont have a spur or pinion for this car. And Is 32p gearing used?
Can anyone tell me what this is?? RC-NUT Oval, Larger Scales and More 6 08-06-2011 07:33 PM
Oh #%@!! What did I do to my SMC Lipos? Freezebyte Electric Off-Road 102 08-31-2009 05:47 AM
New XRAY T1 FC, now what do I use to move it??? jigga21 Electric On-Road 43 08-19-2004 01:24 PM
