ABS vs. nylon wheels? >
Old 03-12-2005, 09:56 AM
SMcpot's Avatar
Trader Rating: 22 (100%+)
Just found out the hard way that you can't boil Yokomo's ABS wheels to get the tires off the rims
Which begs the question......is there any difference, performance-wise, between the ABS and nylon? Given that acetone is supposed to soften plastic, I see no other *safe* way of removing the rubber from ABS rims.
I did a search, but most of the posts were pretty old, so I'm wondering if opinions have changed since '03....
SMcpot is offline
Old 03-12-2005, 05:51 PM
SMcpot's Avatar
Smile
Back up......
SMcpot is offline
Old 03-12-2005, 06:40 PM
jiggen5354's Avatar
i found this out too with yoke rims. also found acetone turns the rims into a soft slurry as well
jiggen5354 is offline
Old 03-13-2005, 10:56 AM
SMcpot's Avatar
Smile
Back up once again.......
SMcpot is offline
Old 03-13-2005, 01:29 PM
fathead's Avatar
You can buy various CA removers that 'shouldn't' melt your wheels, not sure where you would buy it from though, I bought some from my LHS and it worked well
fathead is offline
Old 10-05-2005, 04:10 PM
SMcpot's Avatar
Only problem with CA removers is that they don't "penetrate"; if you've got rubber glued in the grooves of the wheels, this can be a time-consuming process
(Sorry to resurrect such an old thread, but I'm getting ready to buy some wheels, and would like to know if anyone has a foolproof way of doing this without trashing the ABS "super precision" wheel)
SMcpot is offline
Old 10-05-2005, 04:27 PM
I don't think there is a full proof way other than using nylon wheels. Only problem is that Nylon Wheels tend to bend and get out of true. Best bet is to use a new ABS wheel. They are lighter and more precise. Many places like Speedtech have them available in bulk for about a buck each.
pops is offline
Old 10-05-2005, 04:30 PM
SMcpot's Avatar
A buck?? Wasn't aware of that.....thanks!
SMcpot is offline
