Old 02-08-2013, 11:46 AM   #31
Marv's Avatar
Thumbs up
Two RPM Gauges...
A little modding to one gauge for the horizontal mode...
And a self-healing mat with a grid =
DONE!
Marv is offline   Reply With Quote
Old 02-14-2013, 10:25 AM   #32
Marv's Avatar
Originally Posted by M3Armand View Post
No pics?
Today is your lucky day =
Old 04-12-2013, 03:12 PM   #33
HollywoodRC's Avatar
Hey Marv, would you mind posting up a photo of the stand with out the car attached so we can see the stand.
HollywoodRC is offline   Reply With Quote
Old 04-12-2013, 03:29 PM   #34
Marv's Avatar
Today is your unlucky day...
I just finished setting up my car for tonight =
Broke down the station and packed it up about an hour ago
A freshly set up car is like a loaf of fresh baked bread...
Tell ya what I'll do =
I'll slap it all together & take some pics tomorrow =
Check here tomorrow evening after the dinner hour and I should have them up -
Not bad for the price BUT you'll need to get some shims and washers =
I'll post the numbers for those also & take pics of how to string them on -
I've learned to live with mine...
But I only use it before a race...
So far =
Not during a race =
I haven't wrecked bad enough to warrant breaking it out...
Old 04-12-2013, 03:49 PM   #35
Thanks Marv. I am also looking at the Yeah Racing setup station. It's only a few dollars more and looks more like the Hudy.
BTW, I worked on Sin City and we finished Sin City 2 in Feb. Look for it to be out this summer.
Cheers
Old 04-13-2013, 12:13 AM   #36
Marv's Avatar
Many complaints about the Yeah TOE GAUGE not fitting/sliding properly -
The toe gauge on the Integy fits/works underneath -
SWEET!!! Thanks for the headzup!
Cheers
Check back after dinner =
Should be up by then..
Old 04-13-2013, 04:14 AM   #37
Cheers
Great movie!!!
Is Jessica Alba that hot in person?
Here's me with BANE from batman dark night rises in my LHS
JOE SI is offline   Reply With Quote
Old 04-13-2013, 08:48 AM   #38
Originally Posted by JOE SI View Post
Great movie!!!
Yes she is and just the nicest person to work with.
Old 04-13-2013, 05:51 PM   #39
Marv's Avatar
HPI 72111 Shim Set 3x5mm
Four M4 Washers
The number and size of the M3 shims needed per A frame piece will vary =
Placed them on the threaded end, then the A frame piece for the camber, then the M4 washer - with the FLAT side towards the large A frame piece =
This way the small A frame will swing freely -
Integy setup station-dscn4684.jpgIntegy setup station-dscn4685.jpgIntegy setup station-dscn4686.jpg
Old 04-13-2013, 06:12 PM   #40
Marv's Avatar
The pieces don't come marked or matched =
I used a Sharpie oil paint pen =
So that the A frames go together the same way each time for each specific corner =
None of the identical parts are the same =
Each varies to some degree
Old 04-13-2013, 08:33 PM   #41
M3Armand's Avatar
Four M4 Washers
Attachment 1055671Attachment 1055672Attachment 1055673
This looks very similar to the integy setup station that I bought. However, the one I got doesn't have the slop that you mention.
But one question for you is, what car is wide enough to make use of that tow gauge? I find it useless until I find the shorter middle adapter.
Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
M3Armand is offline   Reply With Quote
Old 04-13-2013, 10:49 PM   #42
Thanks Marv. I will do the same when I get mine.
Old 04-14-2013, 04:20 AM   #43
alloyslash's Avatar
Trader Rating: 19 (100%+)
The short bar on the toe gauge is for 1/12 and 1/10tc chassis, and the long one is for 1/10 sc trucks. The design is meant to slide back and forth to the side that you are working on. With all the different track widths that a car can be set up with from the factory, and changed by the racer, it is impossible to make a center bar that would fit every situation.
Pemberton SJ27 / Tekin RS / Cooper D4SS 17.5 / EAM 5000 / Futaba 9551 / 17.5lm
Pemberton SJ27 / Tekin RS / Bullet 13.5 / EAM 5000 / Savox 1251 / 13.5 Pro EDM
TLR22 / Tekin RS / D4SS 6.5 / Futaba 9551 / ORCA 6000 /SCMOD,
F14 carpet Oval Chassis too!
alloyslash is offline   Reply With Quote
Old 04-14-2013, 01:56 PM   #44
Marv's Avatar
I didn't buy mine direct from Integy =
Mine could very well be a quality control reject =
Considering the source & the seller venue =
I wouldn't doubt it for a second...
BUT mine came complete =
I don't know what model you purchased...
Attachment 1019083
Attachment 1019084
http://www.rctech.net/forum/11692093-post20.html
Did you get the color you were looking for?
Old 04-14-2013, 09:56 PM   #45
M3Armand's Avatar
This is what I got. I ended forgetting about the "color" and went for practicality. I ended up getting this one since I wanted to be able to use it for all my cars (albeit requiring more adaptors). I was just using it today for my DEX210. Interestingly, the adaptor for the touring cars was the same for the DEX210. I'm pretty happy with the Integy and I have no tolerance issues needing "washers" or shims. I would say the quality is the same as the Hudy (and I used to be an engineer so you can surmise on my ability to judge quality). The only thing I don't like about it is that it doesn't come with "thumb" screws like the Hudy. So this means that I would have to use a screw driver to put them together. Of course, I can always buy the Hudy thumb screws; which I plan to do so.
Here is the Integy that I bought.
http://www.integy.com/st_prod.html?p...3#.UWt4kEvD_s0
The "short" bar is still not short enough to measure tow for my 10th scale touring car or 12 scale. I need this length of bar:
http://www3.towerhobbies.com/cgi-bin...5&I=LXAWUR&P=K
Or
http://www.integy.com/st_prod.html?p...3#.UWt6a0vD_s0
Hudy or Integy setup station? amdmoto Nitro Off-Road 44 09-21-2013 09:19 PM
NEW Hyperdrive F-1, custom painted bodies, and Integy Setup Station! All NEW Bigcod r/c R/C Items: For Sale/Trade 35 08-18-2007 10:15 PM
Team Orion Advantage Charger (lipo version) and Integy Setup Station V2 DirtyDog3375 Australia For Sale/Trade 6 12-27-2006 07:25 PM
INtegy setup station and hudy board The Rocket R/C Items: For Sale/Trade 16 07-19-2005 07:13 AM
