-   -   will the m8 finally be replaced? (https://www.rctech.net/forum/electric-road/65777-will-m8-finally-replaced.html)
cooliomojo-CEBU 03-09-2005 08:34 PM
i have read somewwhere that the m8 will be replaced this year......have anyone heard about this? it would be great if somebody can confirm.....:cool: :cool:
axel 03-09-2005 08:39 PM
I heard either late this year... or maybe May( doubt it)? I hope they replace the m8 so that I can buy the m8 for a cheaper price.
Totalfixation 03-09-2005 08:56 PM
i want them to just replace it and just use the spectrum built in rather then using a module. i dont think the spectrum will have anything replacing anytime soon. so it will be ok
AdrianM 03-09-2005 09:10 PM
Pro radios will have modules until spread spectrum is fully figured out. Pros prefer 27 band but there are only 6 legal freqs. This means that at a national the top 6 get to run 27 and the remaining 4 have to switch to 75. This is why top level radios have modules. If you are one of the unlucky 4 all you have to do is switch modules, RX and you good to go with your radio and all your settings.
centax error! 03-09-2005 09:22 PM
Re: will the m8 finally be replaced?
... i thought your getting the helios:D
raving-monkey 03-10-2005 01:20 PM
i'm confused, i thought that 75 was the thing to have over 27...same as 40 is more common with the better drivers over 27.
is it something about 75 that makes 27 better?:confused: :weird:
ChrisP 03-10-2005 01:23 PM
Many racers (especially racers who travel overseas) prefer 27MHz because it can be used worldwide as oposed to 75 and 40 which are outlawed in certain areas
CypressMidWest 03-10-2005 01:25 PM
Yes, Channel spacing is far greater on 27 band making it less likely that a driver on an adjacent channel will have his signal "bleed-over" and cause you to have radio hits.
Jarrod Langlois 03-10-2005 01:32 PM
well with the euro split channels you are just as likely to get radio hits on 27 band as 75 because of crossovers/overlapping. seems like the spectrum will be the next best thing for a universal international system.
burbs 03-10-2005 01:36 PM
i would like to see a pcm model from them.. i race oval, on some very large outdoor tracks.. i cant use my m8 there it glitches...
i have to switch to my pcm radio.... always seemed like airtronics had a weak frequency power on all there radios....
cooliomojo-CEBU 03-10-2005 07:42 PM
CE--
yep, imk leaning towards the helios but airtronics might come up with something better than the m8 that they have now.....if they are not changing, once i have the budget, i will go for a helios....
so.....anything definite on the m8 being changed? :cool:
mafiaracers 03-10-2005 09:22 PM
the M8 is like the industry standard....I wouldn't change it toooo much if I were airtronics! if anything, maybe a small area to graph out the expo, but other thatn that, not much....
burbs 03-10-2005 10:36 PM
thats the problem.. standard doesnt mean much.. its the same ole same old.. why not make it better then the industry standard... its been out a long time.. and there is quite a few radios out now i would rather use.. not so muc features, but as i stated above, reliability...
Wild Cherry 03-10-2005 11:01 PM
There is the M-8 Version #3
Its only available in Japan.
Has a faster c.p.u & is only a 2 channel....
got one , its sweet....
axel 03-10-2005 11:31 PM
is it cheaper cause it two channel.
