Hobbywing 150a and EPA >
Old 08-26-2012, 03:42 AM
Default Hobbywing 150a and EPA
hello guys
I have a very important question for me:
the function of the EPA on gas, must be 100% or can I decrease? Change will cause problems to the ESC
puma303 is offline
Old 08-29-2012, 04:46 AM
any help????
puma303 is offline
Old 08-29-2012, 05:32 AM
Originally Posted by puma303 View Post
hello guys
Hi puma303,
The EPA end point adjustment on gas can be set lower. I Use a lower setting when the track gets slick so I don't over power the traction of the track. Some times I'v set it at 55%
I also use this when I let other pepl. use my car to keep them from damaging it if they run into something.
Tim3 is offline
Old 08-29-2012, 05:46 AM
Skiddins's Avatar
Why do you want to decrease the EPA?
Is it not something that can be cured by adjusting the throttle profile or expo?
Skiddins is offline
Old 08-29-2012, 06:12 AM
I disagree, if you don't have the money to buy a slower motor, you can turn down the EPA.
O-and you can use this on nitro cars as well, I know across the pond when it starts to rain, they don't stop. I read some turn down the EPA so the car don't have as much power.
Tim3 is offline
Old 08-29-2012, 06:18 AM
I want to lower the throttle from EPA because I have more control over the model, but someone told me that if I do it this way I risk burning the ESC because of overheating
puma303 is offline
Old 08-29-2012, 06:29 AM
Its the same thing as putting a block behind your trigger finger or throttle stop. can you run your car at half throttle on the track with out it overheating? If you can, there is your answer.
Tim3 is offline
Old 08-29-2012, 08:56 AM
I did not answer this because I've never been able to verify. I guess you know the answer but can you?
puma303 is offline
Old 08-29-2012, 01:05 PM
Is was not meant to be a smart answer. Sorry. and yes you can use EPA.
If you are still unsure, run just a few laps come in and check the temp on the motor.
Tim3 is offline
