Old 07-18-2002, 06:53 AM   #1
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
Default Digital vs Analog servos
Does anybody have any comments regarding the advantages and disadvantages between digital and analog servos?
Thank you
Nick
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
Team Xray T4'17, Team Xray X10'18, TOP Racing Rebel
nnick is offline   Reply With Quote
Old 07-18-2002, 06:55 AM   #2
dtm
dtm's Avatar
Send a message via ICQ to dtm
Digital- more expensive. higher holding power, higher power comsumption
Analog- Cheaper! but still plenty good.
dtm is offline   Reply With Quote
Old 07-18-2002, 06:56 AM   #3
sosidge's Avatar
The digital servo has a chip that checks the position of the servo many times a second, rather than just using feedback like the analog servo.
This increases accuracy.
The digital servo's also have better speed and torque numbers as well.
Old 07-18-2002, 07:04 AM   #4
Shop Owner
nnick's Avatar
dtm: you mean that they don't worth the extra money
Something else too!
Some of my friends have digital servos and I have noticed that a strange noice comes from the servo even when it is not moving! What is that noice, is it normal
Thanks again
Nick
Nikolakopoulos Nick
RC RING
Enjoy RCing....
R/C Tech #82
IRT #123
Old 07-18-2002, 07:15 AM   #5
Cole Trickle's Avatar
In addition to the digital ones advantages metioned above, you should ad, that they got better resolution and their torque are independant of position.
If they are worth it? Well, there are good analog servos for less money. On the other hand, I believe that the steering servo are the most overlooked hop-op and also an very important hop-op. Then add, a servo can last for a long time and can be taken to other cars. Unlike car specific hop-ops.....
Cole Trickle is offline   Reply With Quote
Old 07-18-2002, 08:09 AM   #6
rod_b's Avatar
Send a message via AIM to rod_b
Digital (supposedly) center better and are more precise. However, I don't use digitals in my electric car because it becomes a drain on the batt. There are some nice analog alternatives though. Right now I'm running an Airtronics 94157. It's about 2 years old (newest version is 94357) but it's still very quick and I got it for $40 so no complaints here.
rod_b is offline   Reply With Quote
Old 07-18-2002, 08:19 AM   #7
dtm
dtm's Avatar
nnick, not necessaryily not worth the money....its just that analogy servos are really quite all right. If you have a big budget then digital is the way to go. For most purposes with a digital and analogy servo of the same spec, you will notice very little difference when running the car. I certainly cannot notice any deficency in my KO 2001 (analogy) compared to my 2143 (digital).
Old 07-18-2002, 08:21 AM   #8
dtm
dtm's Avatar
Here is a very good explanation of the technical differences!
http://www.futaba-rc.com/servos/digitalservos.pdf
Old 07-18-2002, 08:29 AM   #9
Regional Moderator
Darkseid's Avatar
nnick: that sound coming from the digital servos (even when not moving) is normal. Some digital servos are louder than other when it comes to this noise, but pretty much all of them make that noise.
I could be wrong, but I believe that noise is the servo constantly checking and re-checking and re-re-checking its center position, so that noise would be from the internal motor. If you try to move the servo from its center position while its on(pysically by hand, that is), you'll hear that noise increase, as the servo fights to keep its center position.
I get the same noise (though not as much of it) from my analog KO Propo 2173.
As for if its worth it, thats up to you. Servos like the KO 2173 have better torque and speed numbers and cost less than 'some' companies' digital models. But its generally agreed that the centering isn't as precise. Centering hasn't been an issue with my 2173, its dead on everytime. Then again this servo isn't exactly cheap($89.95), so I got what I paid for.
Generally, the digital models will run you $15-$20 more. So whether their worth that extra $$$ is up to you.
TLR 22...Tamiya F104...
Old 07-18-2002, 10:13 AM   #10
Boomer's Avatar
Send a message via ICQ to Boomer Send a message via AIM to Boomer
That is exactly what the noise is, the servo is trying to center itself exactly precisely at exact precise center, which is generally impossible, but it tries anyway.
Many (most?) digital servos are also programmable - IF you have the programmer. The only ones that I know of that are available are HiTec's programmer (very expensive) and Multiplex (something like $80) and they only program their respective brand of servo. You can program things like endpoints, speed, dual rate, etc. right on the servo so you can set up your servo and use your controller as a fine tuner rather than to set your DR at like 70 or something - it also means that you could use a cheaper radio. . .
I'm not sure about KO, Futaba or Airtronics, though.
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 07-18-2002, 01:44 PM   #11
Ian S's Avatar
Darkseid - Id say $89.95 is pretty cheap for the 2173, in the UK its 84.95 ($134)!!
Ian S is offline   Reply With Quote
Old 07-19-2002, 02:56 AM   #12
Shop Owner
nnick's Avatar
I thank you all for the info. You have been very helpfull!
Thanks again
Nick
Nikolakopoulos Nick
RC RING
Enjoy RCing....
R/C Tech #82
IRT #123
Old 07-19-2002, 08:11 AM   #13
Regional Moderator
Darkseid's Avatar
Boomer: Heeeyyyy! I got it right. Whooopy for me!
Ian S: I guess it wasn't that expensive after all huh?
Old 07-19-2002, 09:44 AM   #14
Moderator
Cmotif's Avatar
Send a message via AIM to Cmotif
If you are a good driver now, a digital servo will make you a better driver.
Get a digital radio and digital servo, and you will be so much happier with your performance.
I gained so much more control and tunability by going with a Lynx 3D FM and digital servo.
Plus with hi-tecs unbreakable servo policy, you are only hurting yourself on the short and long run buy not paying a little extra for more control and much more durability.
Cmotif <><
International Racing Team Member #18
IRT Established: 1999
Everything About You -- Sanctus Real
www.dontblamejesus.com
Cmotif is offline   Reply With Quote
Mixing digital and analog servos - good/bad? superx421 Nitro Off-Road 12 12-30-2009 09:53 AM
Ko Propo Digital & Analog Servos Hebiki Electric On-Road 54 06-28-2006 08:29 PM
Digital vs. Analog Servos mwcet8k Monster Trucks 19 06-14-2006 12:03 PM
Digital versus Analog Servos Ducati-Rider Rookie Zone 7 06-04-2004 05:16 PM
Digital and Analog Servos voodoo Electric On-Road 2 10-04-2002 06:38 AM
