Trouble drifting
Trouble drifting
So i got 2 pairs of hard plastic tires and i still cant drift it im running a stock motor and everything else only upgrades are 2s lipo and the tires and i still cant get it to drift on smooth concrete I do see something about a rear diff? idk what that is any1 have any other tips to drift? or what i would need to do
Suspended
Throttle control is key and takes practice.
what about the rear diff thing
Just build moderate speed, make a semisharp turn and take your finger off the throttle.
lock the rear diff, makes a huge difference.
how do i do that?
Locking the rear will make a huge difference, check around and you will find lots of ways to do it. Just put something in the diff to stop the gears from transfering power. What car you running?
I'm running a sprint to flux stock everything except i got some hard plastic tires and a 2s lipo i used some paper towel I wet it and i ripped it into small pieces to lock my rear diff didn't think it would work but it did it helped a lot now my problem is counter steering i guess i can barely link drifts but kinda suck badly lol
Interested to hear how long the paper towel holds up, never heard that one before but glad it's working for you now. Just keep at it and it will soon come to you, it takes time to learn how to drift. Good luck and have fun..
should i have to do anything to the camber or anything for countersteering? and good drift tutorial videos?
Try using hardening plumbers putty for locking the diff. It holds up great, and if you ever decided you want to unlock your diff, you can easily remove it and go back to stock. You don't really have to mess about with the camber settings and stuff if you're just starting out, just practice, practice, and practice. You'll start to get the hang of it quickly. Look up "rc drift tutorial" on YouTube, there are many helpful videos I've used to improve at drifting so far.
to start with keep all thos sorts of settings pretty basic(and even on each end/side) and get out and drive.....lots. you will start to get the hang of it and then start to adjust camber etc once you know the effects of those changes. a 2 cell lipo should see a stock motor skid pretty easily so get out and do it
okay guys thanks alot ill give it a shot tomoro
