Old 08-19-2012, 11:30 PM   #1
Trader Rating: 6 (88%+)
Default Trying to replicate a real race car - Wheels/Tires ETC
Ok so I was looking at making a Honda NSX GT body and saw one setup that had green tires.
My main question is this:
http://www.amainhobbies.com/product_...n-2-6mm-Offset
Will these tires fit on any TC?
Also where do I get colored wheels? Specifically orange.
Ironwolf1974 is offline   Reply With Quote
Old 08-19-2012, 11:40 PM   #2
Trader Rating: 27 (100%+)
With 6mm offset wheels, you'll have a flush look with a 200mm body. If you are running 190mm body, you'll just have mad camber.
If you cannot find orange wheels, you can aways buy the wheels in white and paint them with a TAMIYA TS(orange color).
JoeyE is offline   Reply With Quote
Old 08-20-2012, 02:40 AM   #3
Well then I need to find a 200mm NSX Body.
Old 08-20-2012, 11:10 AM   #4
FauxMako's Avatar
Or a 190mm body and 0mm or 3mm offset wheels depending on how flush you want it.
Also, instead of painting wheels you can dye them with RIT dye. It's more permanent than paint as it "soaks in" and you can't scrape it off. Paint will chip and scrape on wheels, so if you run it, be prepared. Dye becomes part of the plastic -- if you cut deep enough you'll see white, but a scuff will show the dyed color and not white like paint.
Mike
3 3Racing Sakura Zeros: Mustang Boss VTA // Lexus LFA USGT // MazdaSpeed 6 TC
Mini M03 & M05
Life is better with a soundtrack
FauxMako is offline   Reply With Quote
Old 08-20-2012, 11:50 AM   #5
If the car is just for standing on the shelf you can run M03 arms and shafts on a TL-01 and you can run crazy wide tires or just mad offsets.
MatsNorway is offline   Reply With Quote
Old 08-20-2012, 12:06 PM   #6
http://www.ritdye.com/store/
That what your talking about? Just put the dye in a bucket and place the wheels in there? Seems easy enough.
Old 08-20-2012, 01:09 PM   #7
Barry_Hughes's Avatar
Orange wheels
http://rcmarket.com.hk/product_info....ducts_id=13464
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 08-20-2012, 01:12 PM   #8
or
http://www.rcmart.com/speed-mind-gt4...l?cPath=35_370
or
http://www.rcmart.com/tamiya-49423-m...l?cPath=35_370
Built it !
Raced it !
Wrecked it !
Old 08-20-2012, 04:19 PM   #9
FauxMako's Avatar
That's it. You have to heat up the water. How long you put the wheels in there does affect the color. You probably won't want to use the pot for food afterwards.
Mike
Mini M03 & M05
