Old 08-18-2012, 11:34 PM   #1
Default Problem with hobbywing esc/motor
Hey, i bought a hobbywing ezrun 9t combo and i seem to be having a problem running them with my tto1-e chassis. The problem is that my car just speeds up slower than it used to, and after a few seconds it takes off and eventually just stalls out. Could i have a bad battery, or did i put too much for the car to handle into it.
sharksoldier117 is offline   Reply With Quote
Old 08-19-2012, 09:43 AM   #2
Sounds like a battery issue.
Just check your running gear is ok as well.
I have seen a TT01 with a 5.5t brushless and it didn't miss a beat, so a 9t will be fine
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 08-19-2012, 11:35 AM   #3
racespecs's Avatar
Try a different battery also check your radio gear and make sure none of the wires to your motor are loose is your motor getting very hot ? if it is your gearing may be too high this can cause your motor to slowly burn out.
________________________________________________
---------RC4ME - JQ - Savox - Alpha - Spektrum---------
racespecs is offline   Reply With Quote
Old 08-19-2012, 02:31 PM   #4
lewis110's Avatar
Also did you calibrate the radio to the esc?
Hobbywing of North America/FalconSekido www.falconsekido.com
Hobby-Pro USA www.hobbyprousa.com
Dialed RC Hobbies/VP Pro USA www.Dialedhobbies.com
lewis110 is offline   Reply With Quote
Hobbywing ESC Settings ONLY cherry2blost Electric On-Road 300 05-09-2017 03:39 AM
Hobbywing ESC's Drift_Buggy Radio and Electronics 827 03-30-2016 11:43 PM
New Xerun 150a/80a esc-motor combo's havatitan Electric Off-Road 1447 07-05-2013 10:16 AM
Help with hobbywing ESC setup RCveteran Radio and Electronics 19 01-15-2011 05:36 PM
