Old 08-17-2012, 09:30 AM   #1
Default Soldering is a Bi!#¤
Why is soldering still in this hobby!?
Why has there not been made clamp and a screw connection on the motors and esc?
http://www.ljudia.no/images/products...16mm-p8478.jpg
Ok. I understand that you might save some milliwatts by soldering your competition car but for everyone else who is not so serious or is not racing a boltet connection should be plenty good.
Sorry, move thread to here please. This forum really need a delete option some time after after you post it.
http://www.rctech.net/forum/radio-electronics-137/
MatsNorway is offline   Reply With Quote
Old 08-17-2012, 09:44 AM   #2
Odin544's Avatar
Trader Rating: 93 (100%+)
Soldering is easy. But you need a decent soldering iron. It makes all the difference in the world. Get a crappy one and even someone who knows how to solder well will have issues.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 08-17-2012, 10:00 AM   #3
You could get his system: reflexracing.net/QTEQ-Power-Terminal-Motor-Connector-Set-LV-Type_p_1058.html
You'd still have to solder that to the motor/speedo.
halldor is offline   Reply With Quote
Old 08-17-2012, 12:18 PM   #4
Its a step in the right direction.
I ended up just driving to my local RC shop and ask them if they can do it. i need a more powerfull soldering iron indeed.
40W is not enough. 60W or more.
Personally think i would have been able to do it with a tiny torch.
Heat it and quickly add tin. done. I also need a bunch of gripers.
I envy octopuses..
Old 08-17-2012, 01:43 PM   #5
Trader Rating: 60 (100%+)
Good heat and zero pressure. I have great luck with my Hako 936 iron.
I love the guys that smash the chassis flat to the table when trying to undo some motor wires.
MC112b is offline   Reply With Quote
Old 08-17-2012, 01:52 PM   #6
C&B RC's Avatar
I envy octopuses..
Yes wattage is important but technique & tip go along way. I use a 3/16 flat tip for most things. Wipe the tip on a wet sponge to get the tip clear, apply a little solder to the tip -should be shiny- this helps transfer the heat. Pre-tin both surfaces. Hold the iron in one place and paint the solder on from the other side, it will be drawn to the iron. A little flux sometimes help. If you pre-tin, may times you won't need any more solder to join the two items. Heat the larger of the two pieces first then add the second. You just need a fillet, not a blob. Fast in and out works the best. Good luck.
It's all fun & games til the flying monkeys show up!
C&B RC is offline   Reply With Quote
Old 08-17-2012, 01:52 PM   #7
Trader Rating: 24 (100%+)
I envy octopuses..
40W is plenty. I use an 18w for most soldering. I like the 60 watt to de-solder. I find the 60w gets too hot, the solder moves to fast and just seems harder.
Have somebody decent show you how to do it. After I watched my friend give me a quick lesson it seemed much easier.
chevmaro is offline   Reply With Quote
Old 08-17-2012, 03:46 PM   #8
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Dialed
http://www.rctech.net/forum/radio-el...ef-lesson.html
Old 08-17-2012, 11:09 PM   #9
Odin544's Avatar
Originally Posted by andrewdoherty View Post
Can never find that link when this subject comes up...
TriCitiesRC.com
Old 08-17-2012, 11:28 PM   #10
kman16jr's Avatar
Trader Rating: 53 (100%+)
I use the new trakpower tk-950 soldering iron and it is great,Heats up from 0-896 in a few minutes and comes with a fine tip and bigger tip.I use the bigger one for everything and my soldering and everyone else looks perfect.
Kevin Welfley
AE rc8b3-AE rc8b3e-AE b64d-AE b6d-AE b6
Sponsors:|DDHrc|Team Trinity|Jconcepts|Rc Adiction Products|NitroPro Fuel|M2c racing|Ultimate racing engines|Highest servos|Bellgate Distibutors|
kman16jr is offline   Reply With Quote
Old 08-17-2012, 11:50 PM   #11
Hi mats
I have for now 20 years used my 50w weller solder iron , its the one with magnetic tips. I know its a expensive one , but you have it for life. Everything can be changed with spare parts. I use a #9 tip and as wide as i can get ,think they call it a "screwdriver tip" with that one i have soldered many packs together back when we were using sub c cells. Another importent thing is the solder tin , buy the good stuff from a electronic shop and not the thick one from your local bauhaus
Xray T4 2014 / Orca VXX / Orca 5t
Team Xray-shop.dk
johnsen-dk is offline   Reply With Quote
Old 08-21-2012, 10:35 AM   #12
mechanike's Avatar
hell i use a propane torch!i just put it on very low,pass it back and forth fast by the connector away from the insulation.don't have to keep the contact with the iron.makes a quick nice solder joint.i have done about 20 connectors with 0 mishaps,,,,,,,,,,,,
1-converted lst-2 into brushless,2 speed and all.Hpi savage XL Modified All Steel Three Speed Brushless WOW!!!!!!.just got a KM-1/530.5 baja!!!!!! only cause i'm single!!
mechanike is offline   Reply With Quote
Old 08-27-2012, 08:51 AM   #13
Trader Rating: 41 (100%+)
From an electrical standpoint soldering is best as it introduces less resistance in a circuit.
Less resistance = less heat = less wasted energy
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 08-27-2012, 11:31 AM   #14
Yea! thats what im talking about. Got pictures?
And what experience do you have with a torch? work related?
Old 08-27-2012, 12:13 PM   #15
CristianTabush's Avatar
MatsNorway, check out a more in depth look at the QTEQ Plugs in this thread. Yes, you still have to solder, but it essentially is one and done. Since the plugs are 24K gold plated and they are screwed on, the pressure between the connection is much higher than "spring loaded" connectors, this leads to much lower power loss.
http://www.rctech.net/forum/electric...esories-4.html
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
1/8 Buggy Tires, PT, Spektrum Receiver, VRC, Lots more Takt R/C Items: For Sale/Trade 16 04-27-2008 04:11 PM
LiPO question zardoz Electric Off-Road 98 10-25-2007 03:42 PM
30 amps vs. 35 Khan48 Electric On-Road 41 12-05-2005 02:23 AM
