Like Tree7Likes
Hot Bodies TCXX
Old 07-22-2013, 08:14 AM
  #1261
Trader Rating: 27 (100%+)
Originally Posted by JJwang
Hey this is JJ,
The track had good traction but we had to use tire warmers due to the fact that the air temp was cold. Well actually my rear end was shortened not widened but still had 3 degree rear toe
What's up stranger!
MDawson is offline
Old 07-22-2013, 08:23 AM
  #1262
mxgregg's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Fred Hubbard
Use the shock spring tensioner to set your ride height.
Thanks Fred.
mxgregg is offline
Old 07-25-2013, 03:46 PM
  #1263
Hi, i would like to have a second set of shocks for my car but i see there is no shocks set for TCXX. Are Tamiya shocks direct fit on TCXX? Wich modifications? How do you do?
CoCoLapin is offline
Old 07-25-2013, 04:20 PM
  #1264
Fred Hubbard's Avatar
As you have found out there isn't a shock kit, you can very easily figure out the parts needed by using the exploded diagram in the back of the 'XX manual.
Fred Hubbard is offline
Old 07-26-2013, 12:00 AM
  #1265
Yes and after i saw that i will not spend over $150 for a second set of HB shock. That's why i am looking for some sort of remplacement.
Old 07-27-2013, 06:43 AM
  #1266
Airwave's Avatar
I am quite surprised that nobody is discussing the modification of the top deck fixation on the motor mount... It really seems the way to go as all the others manufacturers are modifying their actual ch‚ssis this way... Following Yokomo!
Has somebody more informations about how Andy fix the central axle and how many spacers he put under the top deck to avoid contact? It seems that there are 2mm spacers but I can't figure how we can secure the axle in two millimeters...
Airwave is offline
Old 07-27-2013, 10:05 AM
  #1267
jag88's Avatar
I converted my TCXX to match Andy's car as close as I could. I used 2.5mm spacers all around to lift the top deck. I had to make two separate pieces from graphite that would hold the spur gear shaft (central axle) in place. I used flat head screws to attach those pieces. The flat head screws were too tall so I ground them down to fit with some clearance to the top deck. I used the forward motor mount from the TCX and also used the forward motor mount from the TCXX (the one with the belt tensioner) in the remaining hole in front of that. I had to machine a post to fit from the forward TCXX motor mount to the top deck. Unfortunately there is no hole in the TCXX top deck that lines up with the new post. It does line up very close to the end of the notch in the top deck. I used a tapered washer (from a servo mount, I think) to fill the notch and hold down the top deck down. I think I could of used 2mm washers all around but it would have been close.
I ran the car on asphalt (mod) with mixed results. The surface had no grip (not treated) and the car had a push. It definitely didn't look like Andy's car.
It might have been the driver ...
jag88 is offline
Old 07-27-2013, 10:27 AM
  #1268
Airwave's Avatar
Very interesting... Mais that's what I was thinking about... I do have some torn screws which will be fully integrated I to 2mm carbon...
Would it be possible for you to post pictures? I thanks in advance...
Airwave is offline
Old 07-27-2013, 10:50 AM
  #1269
jag88's Avatar
I would like to post pictures but I cleaned up my computer room and now I can't find my camera ... lol
jag88 is offline
Old 07-27-2013, 12:07 PM
  #1270
Airwave's Avatar
Dammit! Did you check in the last drawer? With all the power supplies you keep because you can't remember what they are for... LOL
Airwave is offline
Old 07-27-2013, 12:51 PM
  #1271
jag88's Avatar
no, but that's the first place I'm going to look ! lol
jag88 is offline
Old 07-28-2013, 04:14 AM
  #1272
AGNO's Avatar
I did some tests using a modified TCX top deck, I did not use shims, the central shaft remains in place and there a good flex.
You can change the flex simply re-using two screws.
Post some pictures (sorry for the low quality)
AGNO is offline
Old 07-28-2013, 04:37 AM
  #1273
AGNO's Avatar
I also tested the kit CSO lower shock and towers, and work very well.
I used this setting
Front and rear 350 cps oil and 4 x 1,1mm piston
Front Xray spring 2.7
Rear std CSO sping 2.5
AGNO is offline
Old 07-30-2013, 11:57 PM
  #1274
dvaid852456's Avatar
Where are the pictures of Andy's car? Are they on the web at all? When did he run the modified top deck, which race?
Cheers
David
dvaid852456 is offline
Old 07-31-2013, 01:09 AM
  #1275
AGNO's Avatar
Cheers
David
Andy's car ETS round 5
The top deck of Andy is a prototype, is not yet available
AGNO is offline
