Like Tree7Likes
Hot Bodies TCXX
Old 06-17-2013, 08:42 AM
  #1186
Originally Posted by tc3 racer sc
Should I wait on a up to date version of the tcxx and also I see Andy running the no hole chassis is that the way to go on carpet or run the stock one
As you all already know, we are working on several new option parts for the TCXX and are trying to release them as soon as possible. We don't have exact date for the release as of right now, but i would assume that we would be able to release them all by October this year.
We are planning to have an update pack for those existing tcx/tcxx users, and each single new parts separately.
Thanks,
Hi-LowBlow is offline
Old 06-17-2013, 11:06 AM
  #1187
Trader Rating: 20 (100%+)
Thanks,
Do tell. What are the new parts?
goots is offline
Old 06-17-2013, 02:18 PM
  #1188
We will launch a press release once it's ready.
Thanks,
Old 06-17-2013, 11:43 PM
  #1189
Default Tcxx spring
Hey guys
I bought a used tcxx. The stock spring part number is 6543. Which are supposed to be silver. But on the car and picture on the box are black. Please help
Thx
fx35rc is offline
Old 06-18-2013, 12:49 AM
  #1190
Trader Rating: 29 (100%+)
Originally Posted by fx35rc
Hey guys
Thx
The old (I think you can still get them) silver springs were silver in colour. The new ones (kit silver springs) are black. Both are the same rates, but people say the silver silver ones are a little softer.
Gtr r34 m-spec is offline
Old 06-18-2013, 01:36 AM
  #1191
pro4 springs are black, but are actually marked with the spring colors on the bottom coil of the spring.
goots is offline
Old 06-18-2013, 05:16 AM
  #1192
mxgregg's Avatar
Trader Rating: 32 (100%+)
I want to get a reamer for my A arm pivots. What size reamer do I need? Also will the TCX aluminum pulley HBS 68705 & HBS 68706 work on the TCXX? They look like they won't work.
mxgregg is offline
Old 06-18-2013, 06:02 AM
  #1193
Fred Hubbard's Avatar
The arm was designed to use the pivot ball for movement which is why the pin is a tight fit going through the arm. The pulleys will work but you will need the TCX center shaft
Fred Hubbard is offline
Old 06-18-2013, 06:24 AM
  #1194
mxgregg's Avatar
Fred, Do you run these pulleys?
mxgregg is offline
Old 06-18-2013, 06:32 AM
  #1195
Yep.
Old 06-18-2013, 06:41 AM
  #1196
mxgregg's Avatar
Found the center shaft on Ebay from Hopmeup!
mxgregg is offline
Old 06-18-2013, 07:33 AM
  #1197
Thanks for your help
fx35rc is offline
Old 06-18-2013, 07:34 AM
  #1198
fx35rc is offline
Old 06-18-2013, 02:18 PM
  #1199
Hello Hiro.
I'm trying to open Moore set up pdf at last ETS - (Traiskirchen) source http://www.petitrc.com/. Unfortunately it does not work... could you be so kind to help us? Can't wait to see Andy'setup?
Thank you so much in advance!!
moraccio is offline
Old 06-18-2013, 04:14 PM
  #1200
Originally Posted by moraccio
Hello Hiro.
PM sent!
