Like Tree7Likes
Hot Bodies TCXX
Old 04-09-2013, 08:51 PM
  #946
mxgregg's Avatar
Trader Rating: 32 (100%+)
So I can run the tamiya spool up front?
mxgregg is offline
Old 04-10-2013, 06:33 AM
  #947
Sorry, I don't know the answer to your question. But Tamiya's DCJ's are around $45.00. And with a very light dremel to the steering knuckle and caster block. They are a perfect drop in. And rebuildable.
Juan Aveytia is offline
Old 04-10-2013, 07:54 AM
  #948
mxgregg's Avatar
Looking to find #68769 axle cups somewhere?
mxgregg is offline
Old 04-10-2013, 02:48 PM
  #949
EJ20's Avatar
You can try here. http://www.skmotion.net/SOLID-AXLE-L...cs_p_3499.html
Call them first for confirm availability.
EJ20 is offline
Old 04-10-2013, 03:01 PM
  #950
mxgregg's Avatar
Thanks for the info!
mxgregg is offline
Old 04-10-2013, 04:08 PM
  #951
mxgregg's Avatar
ordered and on the way!
mxgregg is offline
Old 04-10-2013, 07:07 PM
  #952
ShaunMac's Avatar
Glad you were able to find the axle cups you needed.
ShaunMac is offline
Old 04-10-2013, 07:16 PM
  #953
ShaunMac's Avatar
Has anyone experimented with running DCJ's front and rear? If so, what kind of results did you find?
ShaunMac is offline
Old 04-10-2013, 08:11 PM
  #954
ali_g's Avatar
anyone tried running 0.75mm spacers under the suspension blocks?
ali_g is offline
Old 04-10-2013, 10:36 PM
  #955
bigz's Avatar
will the thin steel axles work if i install them in the front? doubting the alum axles. can't seem to find the long axle cups in the front so that i can use 2.4mm axles from my tcx.
bigz is offline
Old 04-10-2013, 11:01 PM
  #956
bukil's Avatar
Trader Rating: 39 (100%+)
I have used 0.75mm FF and 1.25 FR. Anti-dive.
bukil is offline
Old 04-11-2013, 01:39 AM
  #957
AGNO's Avatar
Yes, I Use on high grip carpet surface, work very well.
AGNO is offline
Old 04-11-2013, 10:38 AM
  #958
jag88's Avatar
Anybody know where I can find the TCXX top deck #HB68761. A Main showed they had one but they really didn't.
Thanks.
jag88 is offline
Old 04-11-2013, 11:36 AM
  #959
mxgregg's Avatar
There are some on Ebay.
Thanks.
mxgregg is offline
Old 04-11-2013, 12:20 PM
  #960
jag88's Avatar
Thanks.
jag88 is offline
