Like Tree7Likes
Hot Bodies TCXX
Old 01-24-2013, 02:57 PM
  #676
Wacker1's Avatar
Apart from the HD Bulkheads & GearDiff in the Front, the TCXX was Kit Standard!
Wacker1 is offline
Old 01-24-2013, 03:52 PM
  #677
mxgregg's Avatar
Trader Rating: 32 (100%+)
how do you guys like this car I'm thinking about buying one?
mxgregg is offline
Old 01-26-2013, 09:04 AM
  #678
SuperFastSnail's Avatar
Trader Rating: 82 (100%+)
TCXX is awesome. Arms and hubs are slop free. Highly precision machine. The only downfall is the price, it was a bargain when it was selling for $429, now it's around five big ones.
SuperFastSnail is offline
Old 01-27-2013, 07:07 PM
  #679
Originally Posted by DirtyDog3375
Confirmed. They are direct drop in fit with a 5x10x3mm on the inside of the spindle and kit bearing on the outside.
HTH
Yes they do drop directly in switching the inside bearing out. But just like the directions state for Tamiya cars to dremel some of the plastic off the steering knuckle for clearance. You have to do so with the HPI steering knuckles. BUT, you also have to slightly dremel a little of the C-Hub for clearance. I mean very little. If you don't dremel in both of these area's, The DCJ will hit. When installed it made the steering assembly way smoother. Hope this helps.
Juan Aveytia is offline
Old 01-27-2013, 07:56 PM
  #680
NolanP's Avatar
Car might be going on the auction block. Let me know if your interested.
NolanP is offline
Old 01-29-2013, 03:51 AM
  #681
rbalint's Avatar
Hello Everyone!
Here is Roche's floating servo mount installed on my tcxx. Fits on standard chassis without any modification.
https://lh3.googleusercontent.com/-v...2/IMG_4542.JPG
http://www.roche.hk/shopping/index.p...product_id=730
Balint
rbalint is offline
Old 01-29-2013, 09:07 AM
  #682
theproffesor's Avatar
Trader Rating: 66 (100%+)
Could someone measure the length of the swaybar between the bends for me. I would like to know I I could fit them on my cyclone tc. thanks
theproffesor is offline
Old 01-29-2013, 09:55 AM
  #683
cheehtae's Avatar
Trader Rating: 15 (100%+)
Originally Posted by rbalint
Hello Everyone!
Balint
will this work for the tcx too?
cheehtae is offline
Old 01-29-2013, 10:00 AM
  #684
Craig W's Avatar
yes should do
Craig W is offline
Old 01-29-2013, 10:16 AM
  #685
AGNO's Avatar
Yes, but requires drill a second hole in the chassis.
AGNO is offline
Old 01-30-2013, 06:06 AM
  #686
dvaid852456's Avatar
Hello Everyone!
Balint
What is the advantage of this part over the standard kit servo mounts?
Cheers
David
dvaid852456 is offline
Old 01-30-2013, 07:59 AM
  #687
Airwave's Avatar
Just like all the monobloc servo support...
Make the flex more symmetrical...
Airwave is offline
Old 01-30-2013, 10:44 AM
  #688
Default Front axle
Hi
I need some help regarding putting some dcj on a tcxx. Have read that tamiya 417 or from spec r are a directly fit , but is it possible to fit the tcx dcj from spec r with a tcx roche front spool ?
Fragglerock is offline
Old 01-31-2013, 08:58 AM
  #689
mxgregg's Avatar
Just bought a like new used TCXX. Excited to get it on the track. What is a good motor esc setup for a modified class? From pictures it looks like they use huge pinions. What is a typical gear ratio for a mid sized track?
mxgregg is offline
Old 01-31-2013, 09:00 PM
  #690
Trader Rating: 20 (100%+)
you should ask what the other locals at your track are running. Much more usefull/ practical info.
goots is offline
