Like Tree7Likes
Hot Bodies TCXX
Old 09-23-2012, 10:32 PM
  #226
Trader Rating: 20 (100%+)
Originally Posted by Fred Hubbard
You're welcome Nolan. Yeah not too bad after only having about 9 minutes of track time with it on asphalt for the 1st time. I was able to finish out front in my Q1 putting me 3rd going into the Q2. I made couple of changes and the car felt really good in warmup for Q2 but I stripped a rear belt and was relegated to 4th overall going into the main. My plan was to get a good start and get by 3rd fast enough to stay close to Rick and Barry which I did but hammered 3 different times by other cars thus ending my run. But I am extremly happy with the potential!! We were still able to secure a podium spot with Hiro finishing in 3rd (Nice work Hiro-San!). Attached is my setup.
what is the effect of using the outer hole on the rear hub? Ive been seeing allot of setup sheets lately using the outer hole.
goots is offline
Old 09-23-2012, 11:29 PM
  #227
Korey Harbke's Avatar
The car usually feels a lot smoother. I've found it tends to make the car rotate better in longer high speed corners as well, especially through the middle and exit of the corner.
Give it a shot
Korey Harbke is offline
Old 09-24-2012, 12:36 AM
  #228
Give it a shot
is there a drawback to using it though
goots is offline
Old 09-24-2012, 02:25 AM
  #229
AGNO's Avatar
No Losi 90, that shock setup is or asphalt. On carpet I'm running 550cSt and 1.1mm 3 hole pistons.
With pistons 6x1,1 I use oil 500 Much More and work very well... at the last race with 13.5 Boost I scored the two best best lap of the race, the ambient temperature was 32 c(90f).
Tyres Sorex 36
Track medium grip
AGNO is offline
Old 09-24-2012, 01:00 PM
  #230
NolanP's Avatar
Sounds like I'm sol on finishing my kit. That stupid washer is on back order. I can't find it us or otherwise right now.
NolanP is offline
Old 09-24-2012, 01:56 PM
  #231
The instructions say it's 4.1x11.5x0.2mm.
This might be close enough to work with a little massaging:
http://www.spec-r.com/default/index....roducts_id=162
ID is going to be ~4mm, so you could enlarge that with a file if it's too small. I don't know about the OD, but it's probably in the right ballpark.
-Mike
grippgoat is offline
Old 09-24-2012, 02:38 PM
  #232
NolanP's Avatar
-Mike
Thanks I sent em a message.
Anyone have one of these they are willing to part with? Odd spares.....Fred...Korey? I'll obviously pay for the part and shipping. I want to play with my TCXX this weekend.
NolanP is offline
Old 09-24-2012, 02:44 PM
  #233
Fred Hubbard's Avatar
Tyres Sorex 36
Track medium grip
Nice.
If I had any spares of these I'd send one your way bud. Hopefully in about a week we will have them in stock with our next batch of kits.
Fred Hubbard is offline
Old 09-24-2012, 06:21 PM
  #234
NolanP's Avatar
-Mike
emailed Spec-R and its the same part. Ordered em from Nexus. Thank you!!
NolanP is offline
Old 09-24-2012, 06:25 PM
  #235
Good to hear!
Old 09-25-2012, 11:50 AM
  #236
Default Brand NEW TCX for sale at a bargain price
this is not a for sale section
speed6 is offline
Old 09-26-2012, 04:55 PM
  #237
FYI I just got the word that TCXX parts are slowly rolling in
Old 09-27-2012, 05:47 AM
  #238
Hi did anyone else experience the shafts coming out with the steel out drives? Not tried plastic yet so will have to see. It just seems the shafts are too short for the cups is it the +1mm wider front or something else maybe 46 mm shafts should have been supplied? Thanks J
Jampot is offline
Old 09-27-2012, 08:00 AM
  #239
outtafocus's Avatar
Anyone know where I can find a complete parts list for the TCXX?
I want to order a bunch of parts when I order my kit.
Are the suspension arms the same as TCX? I think that is what Fred had mentioned earlier.
Any other recommendations on parts besides the usual rear hubs, chubs and knuckles?
Never mind, found the parts list:
http://www.hpieurope.com/parts.php?lang=en&partNo=68299
outtafocus is offline
Old 09-27-2012, 09:05 AM
  #240
NolanP's Avatar
http://www.petitrc.com/reglages/hotb...BodiesTCXX.htm
as well you can load the manual
NolanP is offline
