Like Tree7Likes
Hot Bodies TCXX
Old 09-23-2012, 01:20 PM
  #211
NolanP's Avatar
Originally Posted by Fred Hubbard
New customer service hours to better serve you!
Monday - Thursday:7:30AM - 5:15PM PST
Friday:7:30AM - 4:15PM PST
Five days a week, every week!
Customer Service Toll Free: 1-888-349-4474
Direct: 1-949-753-1099
one last question today Fred.
Are you refering to the springs from this?
http://hotbodiesonline.com/piw.php?partNo=75175&lang=en
NolanP is offline
Old 09-23-2012, 01:23 PM
  #212
Fred Hubbard's Avatar
Originally Posted by NolanP
Yep they are in that set but I believe the set only includes one pair of each springs. Here are the pistons I used 68768
Fred Hubbard is offline
Old 09-23-2012, 01:28 PM
  #213
NolanP's Avatar
It does but thats why you update quanity to 2. If not I can use em on the Yok as you suggested earlier.
NolanP is offline
Old 09-23-2012, 01:47 PM
  #214
Dusttt's Avatar
Trader Rating: 144 (100%+)
The 6543 springs are what comes in the kit no? I have always used even on my xray the silvers,blues and pinks. They are great springs.
Dusttt is offline
Old 09-23-2012, 01:49 PM
  #215
Yep.
Old 09-23-2012, 01:51 PM
  #216
NolanP's Avatar
Yep.
I know you have to be completely biased but whats your opinion so far?
I know with the 2012 I had to push the car to it's limits to be able to get a good lap.
So far with the Yokomo I have to take it easy to get a good lap. If I push it I lose time.
What about the TCXX same concept? or in between?
NolanP is offline
Old 09-23-2012, 02:04 PM
  #217
outtafocus's Avatar
I am very interested in going TCXX for this season.
I am coming from the older Schumacher MI4LP, the car was very tough and rarely broke, its biggest issue was a very loose back end.
The original TCX was not a very popular car locally due to being quite fragile.
One local driver seemed to continually be doing very well and would lightly tap a board and snap something in the front end.
Have the plastics been altered or beefed up at all to help prevent this breakage?
I am looking forward to seeing some more of these cars in action.
outtafocus is offline
Old 09-23-2012, 02:10 PM
  #218
Dusttt's Avatar
I am new to hot bodies cars and the set up sheet and just noticed the option for the front arms. I see by flipping them you get a total of 4 different shock mount positions. Nice! now to verify I installed mine correct
Fred,
Did you have different rear arms on your car? I seem to remember 2 swaybar mounts on the same side of yours which explains the longer sway bars that came with the kit. Will this be a future part number?
Dusttt is offline
Old 09-23-2012, 02:24 PM
  #219
NolanP's Avatar
Really I have seen the TCX take some hard hits and walk away un scathed. I def wouldn't classify it as fragile.
It does have a lot of shared parts TCX/TCXX
NolanP is offline
Old 09-23-2012, 02:35 PM
  #220
I don't have to force this car to work the was it supposed to, it does it naturally. The last car I drove was painfully difficult to get it to feel the way that I wanted it to and once I was able to get close I had sacrified so much in other areas it was frustrating. I could get the other car to get around the track and be competitive but it was just too much energy in doing so.
They're much better from what I recall seeing a year or so ago. Case in point, yesterday I got creamed 2 out of 3 times, I'm talking the other car hitting mine and it going end over end and into a wall once...no broken parts!!! That should answer your question
Fred,
They were/are our only arms. I just have a 75115 in #4 hole on the rear arms so I can use a wider rear bar if I'm looking to negate rear grip.
Old 09-23-2012, 02:50 PM
  #221
Dusttt's Avatar
Cool I see the kit came with two extras of those so that makes perfect sense! Thanks and thanks for all the help and the setup sheet!
Dusttt is offline
Old 09-23-2012, 03:32 PM
  #222
NolanP's Avatar
Fred are you running 550cst with those pistons?
NolanP is offline
Old 09-23-2012, 04:28 PM
  #223
No Losi 90, that shock setup is or asphalt. On carpet I'm running 550cSt and 1.1mm 3 hole pistons.
Old 09-23-2012, 04:40 PM
  #224
CraigMBA's Avatar
Trader Rating: 22 (100%+)
When it's 100 degrees in Chino!
CraigMBA is offline
Old 09-23-2012, 04:47 PM
  #225
Like it is right now!
