Like Tree7Likes
Hot Bodies TCXX
Old 09-20-2012, 06:19 PM
  #181
Fred Hubbard's Avatar
Originally Posted by haywood
Fred... Are you attending this years IIC Race? Will Hara be in attendance also? Thanks
I will be there. As of this moment the word is he will not be attending but anything can change. He busy getting ready for the 1/8th Offroad Worlds amongst other races.
Fred Hubbard is offline
Old 09-20-2012, 06:20 PM
  #182
NolanP's Avatar
Originally Posted by Fred Hubbard
Truth be told it's even better than the XRAY diff.
Thats exactly what I am saying Fred. It's the BEST diff I have seen so far. Xray's is nice but I still prefer my Yokomo BD-7 diff over it.
Top Diff hands down is this thing for maintenance.
Are you guys changing the big o-ring every time you change diff oil?
NolanP is offline
Old 09-20-2012, 06:27 PM
  #183
I will be changing oil for the 1st time Saturday morning but I know that I won't have to change the oring due to how well thought out the design for the oring is.
Old 09-20-2012, 06:36 PM
  #184
NolanP's Avatar
Cool keep us updated.
Did you start off at 1000 cst or 2000 cst? Has anyone around you played with the cst in the diff to get the car to kick around the corner better and if so what are your findings at this time?
NolanP is offline
Old 09-20-2012, 11:51 PM
  #185
b_recliner's Avatar
Trader Rating: 22 (100%+)
1) Soon we will have POM's with a 2mm slit so that you don't have to use blades. I believe the POM's in the kit have a 1mm slit.
2) You can put the screws either way.
3) We always run DCJ's so you can run either steel or aluminum in the rear.
Start with Front 1.4mm and Rear 1.2mm. If you need more rear grip run the short 1.2mm and if you need less grip run the wide 1.2mm. Silver springs (kit) all around to start.
Our current 44mm DCJ that you can run is 67699
Which tires?
Correct, I suggest starting with whichever setup you run on your TCX if you're running one.
Sounds like you got a little extra "love" from the factory I'd rather have 3 extra bars then be short 3 bars
Foam tires; sorry I forgot to elaborate that Also, 17.5 blinky.
b_recliner is offline
Old 09-21-2012, 06:21 PM
  #186
Dusttt's Avatar
Trader Rating: 144 (100%+)
DCJ 67699 wont fit my car. They wont go in plastic outdrives, dont fit in purple retainer and wont go in metal outdrives either. The pin is much bigger than stock. It looks like we will need 61087 from the TCX in order to run them.
Attached Thumbnails Hot Bodies TCXX-1.jpg   Hot Bodies TCXX-2.jpg   Hot Bodies TCXX-3.jpg
Dusttt is offline
Old 09-21-2012, 08:09 PM
  #187
2000 cSt on carpet and Losi 100 on asphalt.
We only run rubber tire, I can't help you with foam tire.
Oh boy
Old 09-21-2012, 08:57 PM
  #188
CraigMBA's Avatar
Which tires?
Jaco blues, please.
CraigMBA is offline
Old 09-21-2012, 09:16 PM
  #189
Originally Posted by CraigMBA
Jaco blues, please.
Here you go. If grip is low run the short rear 1.2mm sway bar and if the car pivots to fast/hard run standard HB rear hubs. If the car needs more initial steering run 8.5mm rear droop.
File Type: pdf
Old 09-22-2012, 06:17 PM
  #190
NolanP's Avatar
Oh boy
Ok I ended up with the same issue. Anything? Or am I stuck buying more parts?
NolanP is offline
Old 09-22-2012, 06:49 PM
  #191
CraigMBA's Avatar
TYVM Fred. I'll look you up at IIC and buy you a drink for being such a nice guy!
CraigMBA is offline
Old 09-22-2012, 06:59 PM
  #192
NolanP's Avatar
Well I do have to say after starting to build the car I'm frustrated with the whole djc thing. As well as missing a washer from the gear diff to finish building it. The kit seemed very fairly un-organized. But....The build quality is very very solid so far otherwise. The car feels like it is going to be a beast on high grip carpet/asphalt. I can't wait to get it going....just need to get that washer and figure out what I need to order to run my dcj's.
NolanP is offline
Old 09-22-2012, 08:06 PM
  #193
Dusttt's Avatar
I figured it out two options
1. http://www.hotbodiesonline.com/piw.p...=68770&lang=en
2. http://www.hotbodiesonline.com/piw.p...n&partNo=68769
I'm going with steel and am fairly sure Fred had them on his car today
Dusttt is offline
Old 09-22-2012, 08:15 PM
  #194
NolanP's Avatar
2. http://www.hotbodiesonline.com/piw.p...=68770&lang=en
Not to be hating but it was the same part number on both.
Fred whats the part number to the steel outdrives that will work the the dcj's?
NolanP is offline
Old 09-22-2012, 08:27 PM
  #195
Dusttt's Avatar
Damn iPhone
Dusttt is offline
