Like Tree7Likes
Hot Bodies TCXX
Old 09-19-2012, 07:31 AM
  #166
NolanP's Avatar
Originally Posted by bronc4now
All done
Looks super nice. Enjoy the view with the d3.5 in there it matches the car.
NolanP is offline
Old 09-19-2012, 09:00 AM
  #167
Dusttt's Avatar
Trader Rating: 144 (100%+)
Cars look nice I am building mine. I have a few questions.
1.What front outdrives do you guys suggest. The kit has metal and plastic front out drives for the spool. What do you guys think is best? Obvoiusly the metal ones require you to run blades..
2. I may be missing it but what direction are the screws supposed to face on the spur it doesnt really say in the manual but I see pics on the site that they seem to face away from the motor.
3.My Xray cars have always had the aluminum drive shafts at the back and the steel up front. Is everyone using what the kit says or switching them?
oh and this is the best gear diff I have ever seen period!
Dusttt is offline
Old 09-19-2012, 09:05 AM
  #168
Dusttt's Avatar
Originally Posted by markrobinson
Yep been running my TCX like that every week for two years with no issues
Thanks!
Dusttt is offline
Old 09-19-2012, 09:24 AM
  #169
NolanP's Avatar
Yeah the Yokomo's is the second but the TCXX by far has the best looking diff maintenance and build. That seal and everything looks beefy and smooth.
NolanP is offline
Old 09-19-2012, 09:42 AM
  #170
Dusttt's Avatar
I see it lists the metal outdrives on the spool as a new feature so I guess that is best?
Dusttt is offline
Old 09-19-2012, 09:49 AM
  #171
NolanP's Avatar
If your running mod I'd run the metal. Stock or 17.5 I'd run the lighter weight. If your learning I'd run metal as well.
NolanP is offline
Old 09-19-2012, 09:53 AM
  #172
wwddww34's Avatar
Trader Rating: 9 (91%+)
+1
That Trinity D3.5 motor looks like it was made just for the TCXX.
wwddww34 is offline
Old 09-20-2012, 08:51 AM
  #173
Dusttt's Avatar
More questions.
What sway bars should I sart with? I see in the pro set up tips that they are cutting the silver sway bar but kit suggests black.
What springs are everyone running? just kit?
I am still confused as the suggested set up for the drive shafts should I do it as the kit suggests or reverse them? I looked back in this thread and there seems to be conflicting answers.
Is there a part number for ecs style shafts?
Anyone have a baseline set up sheet yet? I am trying to set up for the Tamiya track this Sat.
Thanks guys.
Dusttt is offline
Old 09-20-2012, 11:59 AM
  #174
b_recliner's Avatar
Trader Rating: 22 (100%+)
anybody have a base setup for medium grip carpet?
b_recliner is offline
Old 09-20-2012, 02:27 PM
  #175
Airwave's Avatar
I think you can totally use TCX setups, even Cyclone TC setups...
"Hara's TC 1.5" would be a good basis I think... This is the one where Atsushi use 1.5mm quite everywhere!
When you are lost in setups, start again from that, the car works not bad and then you can adjust it to your skills...
Airwave is offline
Old 09-20-2012, 04:15 PM
  #176
NolanP's Avatar
Whooo hooo I finally got my TCXX!!!
NolanP is offline
Old 09-20-2012, 05:30 PM
  #177
Dusttt's Avatar
my kit came with 9 sway bars three that dont even fit the car
Dusttt is offline
Old 09-20-2012, 06:16 PM
  #178
Trader Rating: 46 (100%+)
weird
transplantlife is offline
Old 09-20-2012, 07:05 PM
  #179
Fred Hubbard's Avatar
1) Soon we will have POM's with a 2mm slit so that you don't have to use blades. I believe the POM's in the kit have a 1mm slit.
2) You can put the screws either way.
3) We always run DCJ's so you can run either steel or aluminum in the rear.
Truth be told it's even better than the XRAY diff.
More questions.
Thanks guys.
Start with Front 1.4mm and Rear 1.2mm. If you need more rear grip run the short 1.2mm and if you need less grip run the wide 1.2mm. Silver springs (kit) all around to start.
Our current 44mm DCJ that you can run is 67699
Which tires?
Correct, I suggest starting with whichever setup you run on your TCX if you're running one.
Sounds like you got a little extra "love" from the factory I'd rather have 3 extra bars then be short 3 bars
Fred Hubbard is offline
Old 09-20-2012, 07:10 PM
  #180
haywood's Avatar
Trader Rating: 49 (100%+)
Default IIC
Fred... Are you attending this years IIC Race? Will Hara be in attendance also? Thanks
haywood is offline
