Hot Bodies TCXX
#1726
How does the Hot Bodies TCXX compare with Xray T4?
#1727
TCXX 13.5 spec Setup
For anyone interested here is my most recent setup that I used at the last Speedtech Grand Club Race (#8)
Track: Tamiya USA Raceway (Asphalt)
Class: 13.5 Spec
Tire: Reedy Race 2014 Spec Tire Sweep EXP Evo-R 36
Class: 13.5 Spec
#1729
Thanks, I have been trying to get my car set up with a 13.5.
#1730
k_bojar, You’re welcome and thanks!
I used this setup all of last year at 3 different outdoor asphalt tracks with great success.
Only changes I would make..
- If it’s hot out, let’s say above 80F, I would switch to 40wt in the shocks
- With a lower grip surface I would run 2mm under the suspension blocks
#1731
#1733
Interesting you say you use 2mm under the blocks in low grip. Doesn't this raise the roll centre and create less roll? Isn't more roll beneficial in low grip conditions? I'd be keen to know your thoughts, cheers.
#1735
Set up help
Hi Guys, I'm new to TC. I was at TQ in chino last sunday and could not get my TCXX to handle well.
Ride height: 5mm frt and rear
Droop: 6mm frt and 5mm rear
Shock oil: Losi 40 wt frt and rear
Spring: Yokomo Pink frt. Yokomo blue Rear
Tires: Sorex 36
Spacers under front and rear bulk head: 2mm
TCX motor mount.
THanks
Tires: Sorex 36
TCX motor mount.
THanks
#1736
Tires: Sorex 36
TCX motor mount.
THanks
Tires: Sorex 36
TCX motor mount.
THanks
1mm shimms under suspension blocks
Ae 32.5 oil in shocks
Droop 9 front 8 rear measured from setup board to center of hinge pin.
2000wt oil in rear diff
1.4 front 1.3 rear swaybar
Just some setup hints Hiro gave me when I ran on carpet for the first time
#1737
Shock mounting 2hole in front position 4 in back.
#1738
#1739
That's interesting... People were telling me the same... That this chassis is obsolete, not adapted to modern tyres, blah blah blah... It is working perfectly, in blinky 13.5T AND in mod 4.5T. Continue to find some working setup, that's just a matter of trying...
#1740
just wish the part supply was a little better and more consistent instead of those periods where everyone it hunting for parts because the next run of parts didn't start yet
