Hot Bodies TCXX
#1606
thanks, art
one more silly question
I've notice that the TCXX uses a 1.5FF mount and a 1.0FR mount.. I've been running 1.5FF/0FR on my TCX...what will changing the FR to 1.0 get me?
or I guess better question, will swapping chassis (tcx to tcxx chassis) cause me any issues if I keep the same block setup?
Less Sweep/straighter hinge pins
Moves lower shock mount out/increases ft shock angle
wider at the hinge pins should roll a little less
To me it settled my car down a bit and made it easier to drive. But YMMV on that.
No issues come to mind on your chassis question. Someone more educated than I am may have a different opinion. As far as bolting the parts on, the steering rack on the TCXX is a 2mm longer (they moved the holes back to make this work) and will have an affect on ackerman rate.
Art
#1607
I bet Mr. Crisp could write a few paragraphs on that one...
Art
Art
that's cool. I was just wondering what it did, since it looks like the TCXX comes with this setup, whereas the tcx was 1.5/0 - so I wasn't sure how much of a change this would be, or was it something 'required' with the TCXX
yep, I know about the steering rack - and I figure I have 2 options: a) but the +2mm arms; or b) just add +2mm to the rack I already have...
now to get me that TCXX chassis
#1608
Hi. I am sorry to ask what seems a stupid question (since I see no one else asking it on the internet) but what are the recommended servo specifications for this chassis? I bought a KO Propo high end servo with the following specs: 41 x 31.8 x 21mm with weight of 46.5g. But when I tried to put on the chassis, I noticed it could not fit ...it was just a little too long. I then did a search on the internet and noted that HB themselves say that "The TCXX is designed for a 'shorty' type servo but can fit standard-size servos if you mount the receiver on top of the servo". What does that mean exactly? I have not been able to figure it out at all.
Anyway, I have now resigned myself to buying another expensive servo. Can someone please tell me the specs to look for in terms of Length. Clearly 41mm is too long for the chassis.
#1610
Hi Chris. Thank you for responding ...it has amazed me. Maybe I am doing something wrong then ...I am not sure. I will try again after work today and will take pictures if I continue to have the issue.
#1611
...I noticed it could not fit ...it was just a little too long. I then did a search on the internet and noted that HB themselves say that "The TCXX is designed for a 'shorty' type servo but can fit standard-size servos if you mount the receiver on top of the servo". What does that mean exactly? I have not been able to figure it out at all.....
But take a picture of the car with all of the electrics (even if it's not installed) and we'll be able to make suggestions.
#1612
Where can I found the editable setup sheet with pivot block in 2 parts?
#1613
Are you referring to length of of the servo from left to right? And you cant make it fit within the alu kit servo mounts?
#1614
Can anyone tell me if I should uprade my exotek 2mm chasis, lower shock towers equipped tcx to tcxx( cheap arrow max chassis v2, top plate and +2mm steering, new 3hole steering knuckle, cso short shocks. total $170 ) or partially upgrade or play with the setup or.... sell it for cheap and buy a new touring cso-one v2? thanks for your help.
#1615
#1616
Thank you very much for your help!
#1617
I agree. if your running the exotek, and its narrower then the stock TCX chassis - then there's really no need to update to the TCXX-spec. I just did it to mine (except went from stock TCX to stock TCXX) and the 'only' thing I gained was a)narrower chassis; and b)the ability to run a floating servo (I didn't have to drill a whole)
I'd be curious to see where you found a 'cheap' arrowmax TCXX chassis, though
#1618
Go to the source. They are under $50 at Arrowmax-RC.
They even have that alloy chassis fad for cheap! lol
#1619
Ergal vs carbon fiber.
Ready for test!
Ready for test!
#1620
where is your center axle support coming from (on the carbon car)?
