Associated RC 12 R5.2 >
Like Tree24Likes
Old 07-21-2015, 10:09 AM
  #706
Mach10_shooter's Avatar
Trader Rating: 40 (100%+)
Originally Posted by Bubonic-X View Post
How much is the conversion kit?
CM12V2 conversions are $125.00
Mach10_shooter is offline
Old 07-21-2015, 12:46 PM
  #707
Originally Posted by Ted Su(TW) View Post
Is there a rear pod with CRC style adjustable ride height that can be purchased anywhere online?
Thanks in advance.
http://www.zen-racing.co.uk/catalog/...a14f7c70b9ceac
MattW is offline
Old 07-21-2015, 12:49 PM
  #708
hanzo3's Avatar
Trader Rating: 55 (100%+)
I have a lightly used roller if anyone is interested. Thanks.
hanzo3 is offline
Old 07-21-2015, 03:56 PM
  #709
Has anyone tried to run this car in the tranverse position not even sure you can. But it seems as though most of the newer cars run the car that way. Its funny because On the setup sheets it doesnt provide a section on which way you run the battery.
Just wondering
Bubonic-X is offline
Old 07-21-2015, 05:49 PM
  #710
Cosmo's Avatar
Just wondering
I have. I feel like it settles it down. Less twitchy. Seems more consistent from beginning to end on run. I'm using the Reflex transverse conversion kit.
It's for sale if you're interested...
Cosmo is offline
Old 09-11-2015, 10:59 AM
  #711
How do people use the rear side spring adjusters?? Do you thread lock the grub screw to the carbon, and then adjust with the alloy, or do you go R5 style and thread load the adjuster to the grub screw, and screw this in and out of the carbon?
MattW is offline
Old 09-11-2015, 06:07 PM
  #712
Toyota Tom's Avatar
Yes. The set "grub" screw is a pretty tight fit in the carbon. Never had one move.
Toyota Tom is offline
Old 10-19-2015, 09:41 AM
  #713
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
What has been the best body for this car?
Jon Carlson is offline
Old 10-30-2015, 05:48 AM
  #714
EDWARD2003's Avatar
What's the drive side hub offset?
For part # FTP-4608
This is the current part number?
Looking for another hub to match the IRS 3 mm offset hub.
EDWARD2003 is offline
  #715
EDWARD2003's Avatar
AMR
Old 10-30-2015, 10:02 AM
  #716
Plate mounting face, to wheel face is 11.65. Not sure which irs one I have, but I'm fairly sure it's narrower than the ae kit item.
MattW is offline
Old 11-16-2015, 07:33 AM
  #717
I'm ripping apart my car and rebuilding; trying to learn an apply good setup theory but I'm kinda of confused on this car; You'd think 1/12 be simpler.
I'm good on basics such as free pod movement, tweak etc but I'm still confused on oils.
I decided to go back to what the kit manual says and try blue spring center shock and blue side springs. Kit says to use 1000wt oil for the side dampners to start, 30 wt for center shock and 30,000 wt for the front. Is this a good way to go for low traction? I see alot of 15,000, and 20,000 wt for side for I think that is for a different traction carpet.
Because I'm all over the map in handling it seems I figure to go back to basics and then as traction goes up, get to 10,000K. At best all I ever see even in a bigger race is Medium traction so its hard for me to go by setup sheets on petitrc; nobody seems to run low traction with this car.
Any thoughts?
irvinew is offline
Old 11-16-2015, 08:37 AM
  #718
PutAwayWet's Avatar
The 12R5.2 is a great all-conditions car, you can find a setup.
It sounds like you've got the basic mechanical setup down. Always keep track of the center football to be sure your pod movement isn't jacked after a hit. It's the 12R5's one vulnerability and has been since the original version.
Kit setup is a fine place to start, with just a couple changes.
Center spring: The AE blue is usually the right one. Get a CRC red (not the AE red--too stiff!), it's a bit lighter and can help the rear end stay locked down in lower grip conditions.
Side springs: the 12R5.2 lives in the black and green range in all cases. Try blacks to start. Let the car roll. Greens can be a nice option, particularly for Stock. The only issue is that they are big for the spring holders. I fit my green springs to a set of the older plastic spring retainers. Since I hit my alloy spring retainers with a dot of super glue to fix them to the threaded stud, that means I also change out the stud when going to greens. It's a grand total of $1.75 in extra parts.
I run SpeedMerchant green (thin) tube spooge always. I'm going to say it's 5K? Quite light. Pin spooge up front is whatever that's thick and damps vibration. 20K minimum.
The kit 0.020 front springs are a fine spring almost always. They do collapse, so keep extras on hand. They're cheap. Run them with a sliver (0.010") of silver showing below the knuckle.
1 deg. of front camber tends to wear the fronts flat just about everywhere.
After that, it's all tires and sauce. Am I right to think you're running WCICS? If so, you're on the specs. Try a 43/42 rear/front split to start. Sauce the rears for awhile--30 minutes at least. Sauce the fronts inside 1/3 for 10 minutes. Wipe before putting on the track. Adjust the front sauce through the day.
3.5mm ride height. Zero to 0.25mm center sag. 1mm travel-over-ride-height at the center.
AMR body.
That should be a stable, neutral 12R5.2.
PutAwayWet is offline
Old 11-16-2015, 09:38 AM
  #719
AMR body.
Good to know thanks! So I have AE green side springs and black though the black I think are Yokomo. I have a gold AE center spring on order; the spring rate of that seems to fit in line with CRC (10lb to 12lb)
So I'll leave my black side springs in and try 5000wt oil to start; progress higher when traction goes up; on a our club race that might be never. I'll leave the blue spring in with 30wt oil in it.
Yes I'm WCICS; Thanks for the help. Thanks for the tire diameter size; that was another question I should have asked.
irvinew is offline
Old 11-16-2015, 12:50 PM
  #720
Trader Rating: 43 (100%+)
If any one is interested I have a new batch of 2mm chassis finished up for the 12r5.2 please pm or email me at [email protected]
This chassis is BRCA national champion as well as Multiple A main finishes in the US from mod to 17.5. The 2mm offers a lower center of gravity and reduced weight savings for the competitive 1/12 market.
Monti
Monti is offline
