Old 08-15-2012, 01:56 PM   #1
Red face First car
So I just got my first car. It is a HPI sprint to flux with a 2s lipo my wife got for me. I just wanted some help with some questions. I have stock tires and it's hard to drift it can I do anything without getting new tires to make it drift? Also where can I get decent shells with light buckets that aren't too expensive. I was also told it can do 53mph what mods do I need for that. Thanks in advance.
RuEmileo is offline   Reply With Quote
Old 08-15-2012, 02:38 PM   #2
locked's Avatar
Tires - can wrap them in electrical tape. won't last long, but it's a quick and cheap way to make those VTA tires work a bit better for drifting.
HPI make some reasonably priced shells with light buckets. I know their Gallardo shell had light buckets, but they aren't licensed to make Lambo shells anymore. Not sure which other ones might have buckets. At a glance, the Maclaren F1 shell comes with buckets. Take a look here. http://www.hpiracing.com/hpibodies/200mm/
The 200mm bodies will fit better with VTA tires (The tires you currently have, I believe)
Most touring car slicks and drift tires will look better with 190mm bodies (unless they are mounted on offset rims).
Tamiya make a ton of shells with light buckets, but they are a bit expensive.
smaller spur/larger pinion will increase the top speed a little, but will make the motor run hotter, so you need to be careful.
Hope that helps you a little. Welcome to the hobby and to this forum.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 08-15-2012, 09:18 PM   #3
Thank youI went to HPIs website and was able to find a PINION GEAR 34 TOOTH (48 PITCH) can I use any 81T Spur gear or are they specific?
Old 08-16-2012, 04:43 PM   #4
bump
Old 08-17-2012, 03:01 AM   #5
wollow86's Avatar
"I have stock tires and it's hard to drift it can I do anything without getting new tires to make it drift?"
As above, tape. But drift tyres are cheap. So I'd do that.
"Also where can I get decent shells with light buckets that aren't too expensive."
HPI and Tamiya are nice shells for the $$. Most hpi's come with light buckets for the front (should say in the descriptions). The more expensive shells like yokomo and ABC hobby have much better quality buckets for front and rear.
"I was also told it can do 53mph what mods do I need for that."
First thing on the list is more experience. Otherwise you'll be picking it up with a dustpan.
I would say other then that it will be an option pinion (your manual will say which one) and a battery, some brands like hpi/traxxas make a 7 cell battery, which will provide more voltage.
"Thanks in advance."
Your welcome. Have fun with your new toy. But be warned, this hobby can get expensive quick. My advice would be to buy once and buy quality. Saving a few $$ here and there usually leads to more $$ when the cheap bit breaks or isnt quite what you wanted.
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
Old 08-17-2012, 10:04 AM   #6
http://www.rctech.net/forum/electric...on-newbie.html
-Dutch- is offline   Reply With Quote
Old 08-17-2012, 11:25 AM   #7
thanks wollow and dutch
Newbie's first car omegaf Nitro On-Road 29 02-12-2011 12:42 AM
Transitioning from nitro. What should my first car be? sokar Electric Off-Road 42 08-05-2009 08:12 PM
what a good first car? ivoo Nitro On-Road 41 07-04-2008 03:05 PM
new here... my first car purchase. Boltaction Electric On-Road 31 08-04-2006 08:42 AM
first car choice: TB-02 or TA04-SS wankle Rookie Zone 13 06-30-2005 11:55 PM
