Old 03-06-2005, 09:29 PM   #1
Chrisgt2's Avatar
Send a message via MSN to Chrisgt2 Send a message via Yahoo to Chrisgt2
Default Orion V2 Endbell conversion
Ok....just to start off I am a seasoned racer with various A/B main finishes at top races........just so I dont get treated like a noob
Here's my problem, I bought the V2 endbell to run in 19t class at club races to avoid rebuilding twice a day, but when I installed it the motor is Very slow and pulls half the amps it normally does. Thinking it might just be the chemistry between the motor and endbell I tried it on my fastest stock motor and got the same results.......I broke in the brushes and oiled the bushings as well
Has anyone else had luck with the V2 endbell?
Vogan
Hot Bodies Pro 5
*Sponsors*
Hot Bodies, Speed Passion, Team Scream Racing, Rockstar Paint
Franchise Racing Products
The Raceway - Beaver, PA
Chrisgt2 is offline   Reply With Quote
Old 03-07-2005, 08:10 AM   #2
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
top races? yeah right! you must be a rookie!
hey chris,
jimmy has tried it on a monster stock, and it ripped on the robi. he didn't like it on the track, but i know he never put lap times to it. i may goof around with it the next time i'm in there. i'll let you know what turns up.
i like that idea on a 19turn. we're looking to head toward open mod here at the gate, and i don't want to rebuild every run or two either. then again, i may as well just buy a new 7x1 !
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 03-07-2005, 11:18 AM   #3
Joe Pillars's Avatar
Chrisgt2- I have a few questions, I have done allot of testing with this endbell kit.
What springs and brushes are you using?
How long and what voltage did you break-in the motor at?
Kyosho America, Team Orion, Peak Racing, AKA, KO Propo, DiBrino Designs, JTP, RCE, Rockstar Energy Drink, www.thebigrc.com, Portland R/C Raceway (www.prcr1.blogspot.com)
Joe Pillars is offline   Reply With Quote
Old 03-07-2005, 12:26 PM   #4
Send a message via ICQ to Racin_James Send a message via AIM to Racin_James
I had a chance to run one of these with a 19 turn motor on oval. I went as fast with it as I had a noral 19turn. The only thing I foudn was you have to gear up about 5 teeth higher than normal. It is a really effecient setup but does not have the rpm like a normal epic or yok based motor
Racin_James is offline   Reply With Quote
Old 03-08-2005, 05:28 AM   #5
Chrisgt2's Avatar
I was using the hard spring on the + and med spring on - with the edge brushes.
Motor was broken in for 300 sec @2 amps on a LRP Pulsar
I dont know that gearing up 5 teeth would correct the problem.........
Hot Bodies Pro 5
*Sponsors*
Old 03-08-2005, 08:40 AM   #6
Use the medium/hard springs on both sides with the sprint edge brushes.
Break-in sounds about right.
You will want to gear this motor 1 tooth less because this endbell will give the motor more RPM.
Old 03-08-2005, 02:22 PM   #7
Chrisgt2's Avatar
Joe.....hooked up to a 4 cell pack the motor had about half the rpms as it did with the standard endbell on it
Hot Bodies Pro 5
*Sponsors*
Old 03-08-2005, 02:26 PM   #8
Sounds like the brushes are not broken-in all the way. What are you using to check the RPM?
Old 03-08-2005, 02:35 PM   #9
Chrisgt2's Avatar
My ear dyno.......plus I put it in the car and tried it out just to be safe and it was slower than stock with my standard 19t gearing...
Hot Bodies Pro 5
*Sponsors*
Old 03-08-2005, 03:14 PM   #10
speedxl's Avatar
Dude are you for real? come on man !!!
the end bell has bearings supported differently then a conventional endbell and the aluminum absorbs some of the sound.
I can let you hear a motor that sounds like a dud but pulls 2200 rpm more then a motor I have that sounds like a ripper and it slower then the silent one. Dude harmonics plays a role in rpm the motor might be muffled but put it on a dyno and check it out for real. You might be surprized it faster then you hear.
You know I could rip you a good one with a comment like using your ear as a dyno!
But I'll spare ya. !
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 03-08-2005, 06:37 PM   #11
Chrisgt2's Avatar
Thats all I ever use man.....lol....dont need a damn dyno. But like I said I track tested it too
Hot Bodies Pro 5
*Sponsors*
V2 Endbell Conversion thecrow2k Electric On-Road 5 02-14-2007 04:25 PM
Orion V2 Endbell conversion for stock 23T JoeyE Electric On-Road 4 05-21-2006 09:22 PM
One Orion V2 stock endbell conversion left WYLDTHING R/C Items: For Sale/Trade 4 12-09-2005 12:53 PM
V2 Endbell Conversion Kit jw92656 Electric On-Road 1 05-12-2005 12:51 PM
Looking for V2 Endbell Conversion TeamPink91 R/C Items: Wanted to Buy 4 10-27-2004 01:15 PM
