Old 08-09-2012, 06:12 PM   #1
alex1030's Avatar
Trader Rating: 43 (100%+)
Default Best Heat sink / Fan ?
Hi there, I am new to Rctech. I would like to get some recommendations about heat sink / Fan for my T3 running stock class.
alex1030 is offline   Reply With Quote
Old 08-09-2012, 10:00 PM   #2
bvoltz's Avatar
Trader Rating: 44 (100%+)
Have a look here: http://www.rctech.net/forum/electric...oling-fan.html I think you will find your answers here....
And welcome aboard....
bvoltz is offline   Reply With Quote
Old 08-09-2012, 10:23 PM   #3
Jerz616's Avatar
Trader Rating: 49 (100%+)
The fan they are talking about is no longer available. There is one that is just as good and its made by delta electronics. You can find them here.
http://www.parts-express.com/pe/show...number=259-130
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 08-09-2012, 10:59 PM   #4
Trader Rating: 27 (100%+)
These are great fans. I've got them hooked up into both my VTA and 17.5 Spec Sedan. Just be aware that you will have to run them off the receiver and can't solder them directly to battery leads.
If you try to run them off 7.4v, they'll turn on and off and pulsate rather than blow air continuously.
hyujmn is offline   Reply With Quote
Old 08-09-2012, 11:06 PM   #5
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
If you guys mount the fan behind the motor in a standard 1/10th touring car, are you mounting the fan so that its blowing air to it? Or sucking the hot air away?
Dan is offline   Reply With Quote
Old 08-10-2012, 12:29 AM   #6
Jerz616's Avatar
Mounting it behind so it is blowing air onto the motor.
Ryan Gracey
XRAY XB8'14
Old 08-10-2012, 12:53 AM   #7
NR
NR's Avatar
Trader Rating: 52 (100%+)
I swear by the Yeah Racing tornado fans, I run two both facing the motor fr and rr in 17.5 boosted.
I am a little anti heatsinks as I feel they keep heat in, but thats just a personal opinion that could certainly be wrong.
Nathan
NR is offline   Reply With Quote
Old 08-10-2012, 03:18 AM   #8
any photos of diffrent set-ups?
d.k.vmatt is offline   Reply With Quote
Old 08-10-2012, 03:38 AM   #9
kinga's Avatar
Trader Rating: 15 (100%+)
Speed passion heatsink and large 40mm fan. LRP, Novak make good fans. The tornado fan from yeah racing is good also.
http://www.walterrchobby.com.au/inde...-sink-red.html
kinga is offline   Reply With Quote
Old 08-11-2012, 10:20 PM   #10
alex1030's Avatar
Thank you everyone for your suggestions!!! They are really really helpful!!!
Old 08-11-2012, 11:21 PM   #11
NewWestF1's Avatar
Nathan
I'm with you on the YR Tornadoes . I'm running a full Yeah Racing setup; 35A ESC, 10T Brushless and Tornado fan in my FGX .. to date never had an overheating problem even on really hot, humid days ...
.. Sakura FGX; Novak power plant, Exotek, Lotus/Renault #9 ..
.. TB-03 Calsonic GT-R . reventon s/ultra v.3 power plant . yeah racing ..
.. M-05 Mini Cooper, Silver Can 104BK speedo, fakkin' cute!
...one of these days, life will get easier...
NewWestF1 is offline   Reply With Quote
Old 08-12-2012, 12:41 PM   #12
hanulec's Avatar
Id recommend my Side Piece Racing Seis Fans..
http://www.sidepieceracing.com/products/seis/
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 08-12-2012, 02:25 PM   #13
Andy w's Avatar
Maybe a silly question but does anyone notice a difference with just double sided tape and secure it to the chassis. And would it be best to mount it on the front or rear of the motor. I never notice a temp difference when using a heatsink/fan combo. Referring to use on a 1/10 sedan.
Andy w is offline   Reply With Quote
Old 08-12-2012, 02:29 PM   #14
hanulec's Avatar
Originally Posted by Andy w View Post
Maybe a silly question but does anyone just use double sided tape and secure it to the chassis. And would it be best to mount it on the front or rear of the motor. I never notice a temp difference when using a heatsink/fan combo. Referring to use on a 1/10 sedan.
Yes.. just use double stick tape. U mount them behind the motor. Make sure there is enough room from the fan to the motor. Id say you want at least 30mm of a gap..
Old 08-12-2012, 02:44 PM   #15
Odin544's Avatar
Trader Rating: 93 (100%+)
Saw this in the new Yokomo thread and think I'll try it out on my next TC. Just a couple pieces of lexan to direct all the air from the fan to the motor. Great idea.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Whats your favorite heat sink?? Little John Electric On-Road 21 06-13-2013 08:36 PM
factory team motor mount/heat sink jsamarin Micro and Mini Scales 10 09-29-2010 03:21 PM
Heat Sink Battery Bars Accord Electric On-Road 92 01-25-2004 09:13 PM
