Old 03-04-2005, 11:34 AM   #1
jhigga15's Avatar
Default Making a Heat Sink???
Any one know how to make a heatsink for a 540 motor...I am thinking of making one with a special scoop that goes over the engine...like a bend in a river...
jhigga15 is offline   Reply With Quote
Old 03-04-2005, 11:45 AM   #2
jhigga15's Avatar
Here is a picture of what I mean...It's not great, I did it quick
Old 03-04-2005, 11:54 AM   #3
Honestly unless you have machining tools I don't see any easy way to make one...
I would say if you could find an aluminum pipe that is think and has a slightly smaller inner diameter than the outer diameter of the can and is fairly thick then it could be done with a dremel...
here is how I would go about it...
slice the material directly down the center lengthwise so that it can be stretched over the can and fit snuggly.
carefully cut cooling fins that are as absoluetly deep as possible without slicing thru. Run the fins lengthwise for motors mounted on a front to rear axis like in the TC3 or other shaft drive cars.
Slice the fins radially (around the tube) for motors that are mounted side to side (XXX-S, 415, or other belt cars...
Remember that the more surface area the better the cooling, but make sure you use aluminum.....
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 03-04-2005, 11:56 AM   #4
tony q's Avatar
you can the air scoop on ebay for hpi pro4, tamiya evo. same concept.
tony q is offline   Reply With Quote
Old 03-04-2005, 12:07 PM   #5
jhigga15's Avatar
You would also have to angle the fins so that the air passes through...
heat sink doughboi916 Nitro On-Road 6 09-21-2006 08:10 PM
***** LRP Q2 with heat sink ***** wikedgmc R/C Items: For Sale/Trade 1 04-23-2006 10:07 AM
Pls help me with my engine / heat sink dct147 Nitro On-Road 19 05-11-2005 09:06 AM
Heat Sink with Fan Bryan4691 Electric Off-Road 2 11-08-2004 05:59 PM
heat sink !! FlyinGT Rookie Zone 7 04-28-2004 09:05 AM
