Old 08-07-2012, 04:20 AM   #1
Default Tamiya Chassis suggestions
Well im looking for a chassis/kit for racing with mates and possibly novice club racing. Im looking at something from the tamiya.
Thoughts on
ta-06 kit or pro chassis
ta-05 v2 kit
or anyother sugestions
currently have a tt-01e set up for drift
d.k.vmatt is offline   Reply With Quote
Old 08-07-2012, 04:34 AM   #2
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Any of those 2 will get you bashing and racing round the track. If you're going to start seriously racing I'd head down to your local track and see what they're running. You'll then be able to get set up (and possibly spares) help from the locals.
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 08-07-2012, 04:58 AM   #3
I'm currently running 2 TA06 PRO's at the belgian tamiyacup and they are a great value for money and great on the track.
At the belgian tamiyacup i'm running with a slower motor (16T sensorless brusless motor) and i could easily drive my car in a higher class with a more powerfull (they are using a 12T sensorless brushless) motor and still finish in top 4 and sometimes top 3.
With the same motor i would even be competing for winning the race.
I'm just pointing out that this chassis has more potential then most people would say or recomment.
The TA06 chassis is more balanced and has more flex then a TA05 (ver.II) and out of the box the car is allready great.
addicted2blue is offline   Reply With Quote
Old 08-07-2012, 05:05 AM   #4
Is the ta-06 pro woth the extra money over the standard for a first time racer?
Old 08-07-2012, 05:20 AM   #5
Yes it is, cause it has the better alu oil dampers (who are the best on the market) and other alu blue parts wich makes the car lighter and also very importand it has better drive train parts.
It has universal drive shafts wich are way better then the dogbones from the standard kit.
Mostly people are using other motor and tires, standard motor is a silvercan and tires from the kit are drivable but aren't the best ones.
Old 08-07-2012, 06:26 AM   #6
SteveM's Avatar
Trader Rating: 142 (100%+)
Thoughts on
ta-05 v2 kit
If you can find a clean TA-05 V2 then this would be my first choice. The TA-06 is nice, but I don't like the boxy chassis and the bottom battery tray setup.
If you want to see if organized racing is going to be your thing you might consider the spur gear mod and add some TRF shocks and run your TT-01 to start.
SteveM is online now   Reply With Quote
Old 08-07-2012, 06:33 AM   #7
spur gear mod? really required?
Old 08-07-2012, 07:56 AM   #8
I might get the ta-06 pro anyway and if i dont race it will be nice to thrash around the car park with some mates
Old 08-07-2012, 09:01 AM   #9
I think it's the better choice and you won't be disapointed.
When you have the car and ready for building just let me know and i will give you my setup for a good starting point.
Old 08-07-2012, 11:27 AM   #10
SteveM's Avatar
If you stick with the stock Tamiya gears you must use their proprietary 06 module pinions and you are also limited to the gears ratios you can use. The lowest FDR you can use is 5.11 which will not be low enough to be competitive.
Old 08-07-2012, 05:02 PM   #11
Iv chosen to run the sportsman class
and was wonding what the rules mean i can and cant do.
rules
4.3 Sportsman
4.3.1 The Sportsman (previously “540”) class is intended for drivers who are new to RC On Road racing.
This class provides an excellent environment for learning the craft of RC racing. Although, in
some parts of the world 540 racing is a very competitive class with some very seasoned drivers, at
PRECC our intention is for the Sportsman class to be for new and/or junior drivers only.
4.3.2 General Specifications;
4.3.2.1 Vehicle – Any 1/10th scale four wheel drive touring car.
4.3.2.2 Body – Touring Sedan, refer to Section 3.3.2 and also rule 4.3.3
4.3.2.3 Motor – Any brushed 27 turn sealed silver can 540 or Tamiya Sports Tuned motor or Brushless 21.5 turn. Brushless motor regulations as per AARCMCC.
4.3.2.4 Tyres – Rubber tyres only, refer to Section 3.2
4.3.2.5 Battery – As per section 3.4
4.3.2.6 Minimum weight – 1425 grams – ready to race including transponder.
4.3.2.7 Electronic Speed Controller (ESC) – Must be on the ROAR Sportsman Approved List.
4.3.2.8 Approval may be given by the Race Committee to run a non-ROAR Approved
Sportsman ESC. The Race Committee will assess the particular ESC and approve its
operation on specific settings only. The Race Committee reserves the right to
alter/change any ESC settings as required to maintain the spirit of the Sportsman class.
4.3.3 Permission maybe granted for new members to the Sportsman class to use any on road car based
body, provided no advantage is gained. This permission is on an event by event basis only.
Tamiya mini cooper sipaboy Electric On-Road 29687 12-10-2017 04:07 AM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 06:19 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
Custom Cut TC5 Urethane Chassis Protector. Rommel Electric On-Road 51 01-29-2009 12:04 AM
