Old 03-04-2005, 05:56 AM   #1
Default 12x1 vs 12x2
Hello
Which motor will be better for which track? And why? There are special versions of Orion/Peak V2 12x1 HS and 12x1 HT. Please tell me where should be used 12x1 HS and 12x1 HT and 12x2 or 12x3?
Thank you
dicort is offline   Reply With Quote
Old 03-04-2005, 06:13 AM   #2
Pro4's Avatar
As far as I am aware, a single wind has slightly more revs compared to a double wind.
Correct me if i'm wrong!
Pro4 is offline   Reply With Quote
Old 03-04-2005, 06:26 AM   #3
sosidge's Avatar
Revs are similar, if anything a double will be revvier than a single.
The main difference is the feel, a single feels punchier, a double is smoother.
Orion did HT and HS versions of the 12x1 to get the most out of the old european 12 turn limit. HT is torque biased, for tighter tracks, HS is revs biased for larger tracks.
12x2 and 12x3 were less widely used. If the grip is low, and the track is large, I would probably go for a triple rather than a double. Not much in it though.
Old 03-04-2005, 07:30 AM   #4
Are you sure? I heard that HS is for small tracks and HT is for large tracks. I have Orion V2 Touring 12x1 HT with good gearing and i wasn't as fast as people that had 12x1 HS. Luck that i'm better driver and i won Maybe sometging is wrong with my motor.
I have another question about motor tuned based on V2 but i will make new thread.
Old 03-04-2005, 07:52 AM   #5
Rod M's Avatar
so they got rid of that rule? what are the mod rules now for Eur
Rod M is offline   Reply With Quote
Old 03-04-2005, 08:58 AM   #6
There is still limit 12 turn in Europe.
Old 03-04-2005, 09:09 AM   #7
Send a message via AIM to Rudedog55
Default arms
the hs stands for high speed or more rpm's, i believe better for larger tracks. ht is high tourque, i believe better for small tight tracks, the arms are wound on different web size blanks. the orion site has a v2 chat that gives more info than you can ask for and very detailed.
Rudedog55 is offline   Reply With Quote
Old 03-04-2005, 11:08 AM   #8
MartinSorlie's Avatar
From the 1st of August, motors are let free in Europe, even brushless....
Martin Sørlie, 1985, R/C since 1995.
TLR - Spektrum
www.teamsmallsize.com
MartinSorlie is offline   Reply With Quote
Old 03-04-2005, 04:19 PM   #9
StasI's Avatar
no thats right
StasI is offline   Reply With Quote
Orion V2 12x1 Motor ozvena R/C Items: For Sale/Trade 0 07-09-2006 02:38 PM
Difference between 12x1 and 12x2 motor Stein Tumert Rookie Zone 4 03-01-2006 06:31 PM
Trinity Cobalt 12x1 out_to_lunch R/C Items: For Sale/Trade 3 10-03-2005 06:24 PM
how low can i go to a com.(Rheinard World Ed. 12x1) belgianchamp Electric On-Road 5 09-01-2005 10:01 PM
